Media Official 35" and under!! Post pictures!!
Photo/Video/Audio threads
do you have any pics out in he sun light?
What size tarp?
Slumberjack Roadhouse Tarp
I have a foxwing awning however it was damaged in the wind at the beach. The slumberjack provides more usable space and is at least 1/3 the cost.
Thank you. I am going to do the same. More flexibility, coverage and portable...
315/75r16 KM3’s
OME J’s in front and mediums in the rear
850J & 860, no spacers? If so, this is where I’d like to drop to. Same tire size but PO installed Js all around with a spacer to level the front, and it’s a little taller than necessary. If possible, do you have your center of hub to bottom of flare measurements?
It’s about 23.5”. This is the second 80 I’ve ran this setup on and I’ve been happy with it. No rubbing and it sets and handles how I like it
Right on, thank you sir. I’m at 24.25” so that drop will do the trick, plus medium rear will surely improve my light ride.
I like the stance....what other components have you had to install to make this set up work?
I used some man a fre control arm drop brackets for caster correction and it drives like stock with no vibes. I need an alignment though. I’m planning to get a delta panhard bracket for the rear.
