Build fzj80 projects.. turbo, h151, unimog portal swaps etc..
Member Build Threads
my bone stock v8 uzj100 vs heavy fzj80 turbo.. 100 runs earlier but cant change result :)
Well, that sure answers a lot of questions. :lol:
Bize gösterdiğiniz şeyler, bence, turbo ile 1FZ'nin gerçek gücünü merak eden insanlar için gerçekten yararlı oldu.
new info screen
Gerçekten çok ilginç...
You using the 1HZ/1HD-T/1PZ/1HD-FT/1HD-FTE thermostat? They use the same gasket (16346-66020)
90916-03089: 76C opening temperature, 90C fully open.
90916-03117: 82C opening temperature, 95C fully open.
So you are using a thermostat that opens at a cooler temperature and is fully open for coolant flow at a cooler temperature as well.
Çok güzel çapraz-kullanım. :)
So you converted your stock cap and rotor to coil packs? what did you use for the distributor? Please post a list!!
only 20000cst oil and 1hz thermostat push down cruise temps from 90c to 83c.. waiting for radiator effects...
aynen abi uyumlular, cok basit bir modifikasyon..
Man o man, subscribed!
