I am in the process of having my crank repaired, I had a harmonic balancer fail and damage the snout.
I am planning on replacing the BEB's while I am in here, but I have been running into trouble figuring out which size bearing to order.
I incorrectly assumed that I could discern the bearing size based on the numbers stamped into the bearings themselves, however all of my bearings have the exact same number stamped into them. "C1-1436 STD NDG"
I have read the FSM and understand that I add the number stamped into the crank, to the number stamped into the con-rod, and that will tell me what size bearing I need. Unfortunately the crank is at the machine shop, and I did not record the numbers before I dropped it off.
My understanding is that these bearings were replaced by Land Cruisers Direct when they imported it for the previous owner, almost exactly 100,000 KM's ago.
Can anyone tell me what these BEB's are? Are these the ACL "one size fits all" bearings? Again, every bearing has the exact same stamping in it.
I think that my best path forward at this moment is to visit my crank at the machine shop, get the numbers off of it, order the OE size bearings and then check them with plasti-guage during reassembly? The Crank looked to be in great shape other than the damaged snout, BTW.
