OEM Windshield question for CDAN
I recently had a winshield replaced under insurance and specified an OEM Toyota windshield. The shop did not follow my wishes and installed what they claim is a high quality substitiute.
My question, is OEM replacement glass through the dealer actually a Japanese made true OEM glass as originally installed or is it made by one of the North American suppliers.
The shop will replace the glass but I don't want to be picky about it if there is no real benefit.
Some Toyota vehicles do use factory-installed glass that is made in the USA. The 80 series is not one of them. So, a factory glass for an 80 is Japanese and it says "Toyota" in the lower LH corner.
Agreed, that glass should be urethaned in, both between the glass and weather strip and the weatherstrip and body.
The install job apears to be fine...
I have watched the OEM glass take rocks that would have destroyed other winshields. Looking to maintain that integrity if I can. Will probably just leave well enough alone and see how it holds up. If it turns out to be inferior I can always switch back.
Where does one score an OEM windshield - dealership?
Yup.
Don't the windshields on the higher end vehicles have something made w/ the glass?? I've noticed since I bought the LC that the windshield beads water like my Porsche does. It's hard to explain, it's like theres wax on it and it always wipes clean w/ the wiper blade. I have various other cars and trucks and they are diffrent as far as the glass goes, leaves a wet film when wiped.
My last Jag had a very thin defrost wire inlay in the windshield... barely noticeable. And it made the water bead-up. Maybe your Porsche has the same?
Just noticed your RX7 with the Nasty former-302... that's scary, man! Keep those rings lubed!
I know this is a useless comment, but I sure do hate windshields. I seem to be buying one every couple of years.
If you are worried about your new one, I'd say don't sweat it. You'll probably break it again soon enough and you can get a real "T" next time.
Treated glass
Some high-end vehicles just in that past few years have factory-treated windshields that repel water/bugs/etc. Some of the newest Lexus products have it, and I think the 4Runner has it in the last year or so.
There is a windshield washer fluid that has RainX in it, (about 3.69/gallon) made by Prestone (?) and it works well and applies a small amount of RainX to your windshield when you use it. This might be a good poor-mans approach to the problem, assuming you use your squirters.
Steve
Last year I had OEM front glass installed and I was informed there was only 11 left in the country! I don't think this is a true statement though. Dan could you confirm?
Yow, probably an import from Japan... that's a pricey meatball.
Mental note: no more tailgating on gravel roads.
Actually not that bad. the 91-96 glass lists for $252.94 and the 97 glass is $314.13.
Currently there are 13 91-96 windshields in depot stock and I have one in my glass rack. There are 12 1997 windshields in depot stock.
I do not know what the physical differences are between the two glasses. Fitment wise they are the same. I do know that the original glasses were not shaded. The Current part number for the 91-96 is a shaded glass.
I don't suppose you ship glass?
What's the PN for the 91-96 shaded glass?
Thanks,
Dave
