OEM throttle return spring..............
Prescott Valley, AZ
So part number 90506-09005 for years 9/75-7/80 is no longer available. I have searched my local hardware store with no success on a spring with right length or more importantly tension as mine has gotten weak. What are folks using on their OEM Aisan carbs?? Help
Thanks guys!!
I bought a universal one at NAPA, won't work. Thanks for the input Tools, one of those looks close...........
first time mine broke (coming off I-40 in Flagstaff to go onto Rt. 89, stopped at the Maverick gas station), I re-used it: I cut off the fatigued part and used the shorter spring :hillbilly: - it worked for a year
the next year, it gave out at exactly the same spot :bang: :lol: (that spring just doesn't like the loooong climb up I-17 :doh:) - I had a spare from the hardware store in the parts box :p
(I had taken the old one to my local Ace and searched around for quite a while to find a slightly longer one with what felt like the same springiness, cut that down and bent the loop to size; took it along in the spare parts box)
Gota check those out-thanks all. Was going to put up the NLA part number on the unobtainium thread.................
Hey I saw this old thread on throttle return springs
In the idea of the proper one to replace it what did you end up using
Thanks I’m in the same boat
Is this what youre after? What year is your 40?
Wow
Thank you so much I just bought one
