Oem or better?
The West
ok i just got back from picking up some parts today down at steven creek toyota.
i need opinions as i am trying to make a conclusion
i am in the middle of researching these three things:
starter - oem rebuilt or better?
brake booster - oem $1000 or better?
and clutch disc and pressure plates ( also slave and master) oem or better?
If the starter is for a 40 make sure it is a gear reduction. They spin over faster and have that new car sound. I have a rebuilt toyota one in my 40 and a mean green in my 60. I cant tell the difference.
I recently went through the brake booster thing in my 79 40 and had to settle for a booster from a 98 tacoma. it looks different than the stock one but fits and works great. It still a toyota part and it only cost $30.
I am a strong believer in centerforce clutches. they have the best of both worlds. Easy operation and superior clamping.
Of these items the booster is the only one that I would think would stand out as something that could detract from value if you didn't use the exact match.
Definitely go with the gear reduction starter. You can sometimes get them pretty cheap on ebay. Cruiserparts has them listed for $50.
http://www.cruiserparts.net/parts/fj40.htm
There are a lot of brake boosters suitable for a 40. You don't need to spend anywhere near $1000. Search booster.
Stock and standard aftermarket clutches are fine for a stock truck. Same for the cylinders. All of the normal LC vendors have suitable products listed. I wouldn't install a centerforce if it's a stock truck.
I bought my '78 from Stevens Creek just a little over 29 years ago. They owe me 29 years worth of free oil changes. It's not their fault. I spent a couple of years sailing around on the Pacific after buying the truck and then moved away. I wonder if they would ship me the oil and filters now. :D
thanks for all the info. SO rukowh a 98 tacoma booster will bolt right up?
just to give ya'll the details: I am restoring a 1970 fj40 with an already swapped 1977 motor that i am going to have mated to the efi setup of later model cruisers and a aussie 5 speed and 86 split case. Stock height no lockers and sag power steering.
as far as the starter looks like i can get a gear reduction. sweat. this sounds alot better than a rebuilt or bosch.
and
it sounds liek oem or the centerforce for the clutchj disc and pressure plates.
any other suggestions. i will get to researching now. haha
thanks!
Any toyota mini truck booster will bolt up if it has the same bolt pattern. I used a 98 tacoma booster because it was the newest in the boneyard and they were all the same price. the only thing you have to do to it is cut about 1/2" off of the end of the threaded shaft to make the pedal height work out right. Some people use spacers between the booster and firewall instead of cutting. This is probably the best method. I noticed that some of the older ( 91'- 94ish) 2wd trucks had this spacer from the factory. I picked up parts on a friday afternoon and put it together on a sunday morning so running back after the spacer wasn't an option for me. I had read several posts about this install so I knew about cutting the shaft before I started and didn'think abot the factory spacer until too late. I don't know if a 91' truck booster would be a perfect fit or not but I do know that a 98' tacoma booster with the spacer plate from a 91 would need no other mods. The whole thing was quick and painless and one of the cheapest repairs ive done.
You have a 1970? Does it have a booster now?
yes i it has the booster. my brakes are from a 1975 ish or 77 the brake master and booster at least
Any toyota mini truck booster will bolt up if it has the same bolt pattern....... The whole thing was quick and painless and one of the cheapest repairs ive done.
great info. i seem to have had my unfair share of brake booster issues. rebuilds dont seem to last too long and the aftermarket boosters have been junk. next time i will go for a taco booster.
Ok, I went through the same thing at Stevens Creek Toyota, here's what I did:
- Starter: OEM rebuilt but when my FJ60 starter showed up at the part counter, it looked brandnew :bounce: :bounce2:
- Brake booster: brand new OEM, I paid around $500 for mine I was told it was the last few in existance, I know I don't have to deal it with it again for a long time.
- Clutch disk/ pressure plate: Again Toyota OEM, it was cheaper yet very high quality.
Toyota all the way please and that's my choice yours may differ:)
Btw, those folks at Stevens Creek are pretty cool, I got to know almost all the guys/gals running the part counter, and saw them moved to different things, even one nice part guy passed away...At that time I realized that I've been screwing around with my cruiser for too long :eek:
thanks alot. yea i have just decided to go oem all the way around to.
also i have been doing some hunting and it looks like Asco / Aisin still makes this stuff as well according to autopartswearhouse and other online parts stores. Asco / aisin makes the parts for toyota in fact their company is owned by toyota to my understanding. SO they are the same quality parts as toyota / better? or worse?
I have some questions:
Starter i have figured out. OEM toyota remfg. for 1975 and up gear reduction starters. ( thanks, all your opinions really helped)
Second of all I have a 1977 motor in my 1970 truck and i am swapping a h55f into the truck as well as a 86 split case. I also have a front disc brake conversion from a mini truck.
heres the questions . what years should my brakes be from : clutch slave, master, disc and pressure plate etc.
also what years should my brakes be from: BRake master , and booster sence i have the mini truck conversion.
I also have checked and toyota sells the Toyota Rebuilt Boosters for 700 bucks with the tlca discount. what should i do about the booster? I don't want to swap anything just to get a booster. I am looking for something thats new and bolts in. what brand or other model toyota should i get the brake booster from ( strickly bolt in)
thanks for all your help.
I beleive '75 (mine) and some newer FJ40s still had the old big-0-starter, to be safe ask for an early FJ60 starter, return your core later and don't forget to remove the part number from the core because they will reject your core if the part number doesn't match. Don't tell them I told you that :) .
Personally in my opinion, I wouldn't mess around with H55F/FJ60 xfercase, it's more expensive and you don't get that much more out of it. Go with the cheaper H41 and git-r-done with Orion 4:1 xfercase, for overdrive I would just get larger tires :D.
I still used my stock (bought new from Toyota) '75 FJ40 brake master, it works perfectly with the 4Runner V6 calipers front and FJ60 calipers in the rear.
Don't pay that type of money for a booster, rebuilt or not.
I would go GM before I paid that type of money, plus parts would be found a lot easier found with the GM M.C. and booster. MAF sells a good little kit.
any bolt up masters though? Toyota part prefered. obviously ive decided i can't afford a new rebuilt booster for my truck from toyota.
any other model toyota booster that bolts up?
anyone with a link or anything?
X2.... i could think of a lot of things i could spend 650 bucks on after i put in a 50 dollar junkyard booster.
heck, even spend 100-125 on a booster and you'd still have a big chunk of cash to put into driveshafts and the crossmember that you'll need with the h55f swap
malphrus
Copied from REZARF.
"FWIW, I bought a 86 mini truck booster and MC for 40 bucks at the local yard, just make sure to get the check valve off of the firewall that runs to the engine or you will make two trips like I had to "
This seems to be the way to go.
Is there anything wrong with your booster as of now?? If it was shot, a rebuild kit can still be bought but your lookin at about 300 for it.
I'm gonna need to go with power brakes on my 66 within the next couple of weeks. Just wondering if you have any pics of the 98 taco booster installed in your rig. I did a seach and didn't come up with a whole lot of info. Thanks in advance.
Kevin
