John,
Going to run r134a. Its way to cheap compared to r12 these days. I drained and flushed everything, and have a new reciever dryer to use, plus all barrier wall o-ring hoses. If you are going to convert, you will have to make new hoses, since the old r12 hoses arent barrier wall and wont hold r-134a for long.
Too convert you need to get new hoses made, change compressor oil to PAG or Ester, and get a new reciever dryer. Lots of good reading online if you search "converting to r134a" on google. Do not just use those crappy kits at autozone. You need to evacuate the system, vacuum it down, ensure it holds a vacuum, and then charge with r134a. Best to take it to a shop, but do the cleaning/flushing work yourself.
Lou,
firewall grommets are discontinued, so I have raided all the ones I can find that are the same size from older toyota cars when I go to the junkyard. Not too many have the correct sizes, but from time to time I find ones that fit.
Brett what were the original hole sizes? I wonder if these would work?
Grommet Single #6 - #10
5x6x16 more or less.......sure would be nice to find a source for new ones......HTH
