OEM NipponDenso A/C expansion valve retrofit
AC fire wall grommet measurements
Marshall, Brett; here are the grommet measurements
3/8=10mm ID x 1 1/4=32mm OD
5/8=16mm ID x 1 9/16=40 mm OD
they are pretty dried out though:frown:
HTH :cheers:
Lou
test your stuff yourself!!
:mad:...continuing this thread......was told by the Birmingham reps for "Vintage Air" that my evaporator was bad but they could give me a good deal and install a Vintage Air unit for a price of ONLY 2600$:frown:
:hhmm: took Brett's and Marshall's advice and rigged up a little pressure tester, was not able to find a way to install the schraeder valve....spent several hours at Lowe's and HD without finding all the items needed to set it up:frown:
So, I capped one end off and jammed an airline in the other end got the pressure up to nearly 150 psi and could not get the evaporator to bubble when submerged:confused:..........thinking I was screwing up some way or other decided to take it to a radiator shop........."Norris Radiators" and they told me that after pressurizing both the evaporator and the condenser to 175 psi there was no leakage:hhmm:..........
question I have; would you pursue the "leakage over time" test or just go with Norris Radiator and my results? TIA
Lou
quote=n2666s;3768123]Brett;..... a bit disheartened today ..........here is the deal; got my stuff back from Birmingham.....their quote was ONLY:eek: 2600 $ for Vintage Air install using the underhood stuff from my 74.....was told that there was a leak in the evaporator but they did not or could not tell me if it had been tested with the expansion valve off?!:frown: am a bit at loss on your suggestion for a pump set up to test it.........can follow directions but have difficulty visualizing the set up without pix:frown:.......did take a printout of your recommend for a test set up and got some very blank stares at the local AC place :hhmm: Questions;
#1.. is there another evaporator that might fit?
#2..how did you install the Sanden compressor?
#3..can you please post pix of your set up?
TIA
Lou[/quote]
I would attempt using the ND evaporator... When reinstalling the copper hard lines and the new expansion valve, be sure to get the flare fittings tight. the only leaks I have had on mine were at the flare fittings. I will warn you ahead of time, getting a used flare fitting to seal takes a lot of effort. might have to tighten the crap out of it, or at least seat and re-seat the fitting a few times. leak test with a little pressure and some soapy water on the outside of the fitting...
expansion Valve TXV from Kragen
Brett; priced the expansion valve part # 4608 here locally at O'Reileys/Kragen and it was 53.99 with out taxes....:hhmm:notice your price was a lot lower..........did they give you a discount? or is this number correct?......seems like an awfull steep jump in price in a few months:frown:.......another question; did you replace the styrofoam inside the evaporator housing?......mine is total crap:frown: TIA
Lou
Now,you will notice the shield doesnt fit anymore, so trim like this:
Then its time to do a leak test. I bought a 5/8"(IIRC) flare cap and capped the large outlet. With a rubber nipple on the blow gun, I applied air pressure to the new tube and sprayed a mixture of soapy water from an old simple green spray bottle. Any leaks will show up by making bubbles. Tighten down the fittings and then its time to recover all the copper with the prestite tape. Leave room for the firewall grommets and re-install(or install for the first time) your re-fitted evaporator....
good luck.
TXV valve from Kragen/O'Reilly's
imitation is the highest form of flattery;)
:hhmm:wondering what to do about the cracked styrofoam liners but did continue to clean up the parts before putting things together!
Talked with the local peeps at Kragen/O'reilley and they can order this valve; it seems different in appearence on the "probe" side from the one Brett installed and in my ignorance of AC units wanted to get an opinion if it might work....specially with the fact that it will be a special order that must be payed for before ordering:frown: TIA.......
Lou
Lou
O'reilly bought kragen etc, and they arent listing the the factory aire line anymore. might try instore? I have purchase a few different brands, and had various pictures, but all showed up exactly as the one I installed. I think Parker makes them for all the companies, as the parker "P" is on all the ones I have purchased.
TXV valve cross reference "expansion valve"
:wrench:got this off the Kragen website; lots of info here:hhmm:
Ready-Aire Expansion Valve:
Part Number: 4608
This product fits the following vehicles -
AMERICAN MOTORS
1958 - 1974 AMBASSADOR
1970 - 1978 GREMLIN
1958 - 1968 AMERICAN
1970 - 1977 HORNET
1973 - 1974 AMX
1968 - 1974 JAVELIN
1978 - 1980 AMX
1971 - 1978 MATADOR
1961 - 1966 CLASSIC
1975 - 1980 PACER
1978 - 1983 CONCORD
1979 - 1983 SPIRIT
1980 - 1988 EAGLE
AUDI
1971 - 1974 100 SERIES
CHRYSLER
1975 - 1979 CORDOBA
DODGE
1964 - 1970 A100
1974 - 1976 DART
1967 - 1970 A108 VAN
1977 - 1979 DIPLOMAT
1977 - 1979 ASPEN
1978 - 1979 MAGNUM
1978 - 1983 CHALLENGER
1978 - 1979 OMNI
1971 - 1984 COLT
1983 - 1986 POWER RAM 50
1984 CONQUEST
1983 - 1986 RAM 50
1979 - 1982 D50
1979 ST. REGIS
FORD
1978 - 1987 BRONCO
1971 - 1974 F-250 PICKUP
1988 - 1990 BRONCO II
1975 - 1987 F-350
1968 - 1969 COUNTRY SEDAN
1971 - 1974 F-350 PICKUP
1971 - 1974 COUNTRY SEDAN
1965 - 1970 FAIRLANE
1965 - 1979 COUNTRY SQUIRE
1978 - 1983 FAIRMONT
1987 - 1990 COUNTRY SQUIRE
1965 - 1970 FALCON
1972 - 1982 COURIER
1978 - 1980 FIESTA
1965 - 1972 CUSTOM
1975 - 1982 GRANADA
1968 - 1977 CUSTOM 500
1967 - 1986 LTD
1971 - 1983 E-100 ECONOLINE
1987 - 1990 LTD CROWN VICTORIA
1975 - 1991 E-150 ECONOLINE
1978 - 1979 LTD II
1971 - 1974 E-200 ECONOLINE
1969 - 1977 MAVERICK
1975 - 1991 E-250 ECONOLINE
1964 - 1973 MUSTANG
1971 - 1974 E-300 ECONOLINE
1979 - 1987 MUSTANG
1975 - 1991 E-350 ECONOLINE
1974 - 1978 MUSTANG II
1981 - 1985 ESCORT
1971 - 1980 PINTO
1982 - 1985 EXP
1978 - 1979 RANCHERO
1975 - 1983 F-100
1988 - 1994 RANGER
1971 - 1974 F-100 PICKUP
1984 - 1985 TEMPO
1975 - 1987 F-150
1977 - 1982 THUNDERBIRD
1975 - 1987 F-250
HONDA
1976 - 1981 ACCORD
1973 - 1979 CIVIC
INTERNATIONAL
1973 - 1980 SCOUT II
JEEP
1974 - 1990 CHEROKEE
1968 - 1973 J-2500
1966 CJ3
1968 - 1970 J-2600
1966 - 1983 CJ5
1972 - 1973 J-2600
1966 - 1975 CJ6
1968 - 1970 J-2700
1976 - 1986 CJ7
1968 J-2800
1966 - 1967 COMMANDO
1968 - 1970 J-3500
1961 - 1967 DISPATCHER
1968 - 1970 J-3600
1966 - 1972 DJ5
1968 - 1970 J-3700
1966 - 1968 DJ6
1968 - 1970 J-3800
1961 - 1966 FC150
1974 - 1988 J10
1963 - 1966 FC170
1974 - 1988 J20
1963 - 1967 GLADIATOR
1981 - 1985 SCRAMBLER
1998 GRAND CHEROKEE
1963 - 1967 WAGONEER
1984 - 1991 GRAND WAGONEER
1972 - 1988 WAGONEER
1967 - 1971 J-100
1987 - 1990 WRANGLER
MAZDA
1972 - 1977 808
1971 - 1972 R100
1972 - 1976 B1600
1974 - 1977 ROTARY PICKUP
1977 - 1978 B1800
1971 - 1974 RX-2
1979 - 1981 B2000
1972 - 1978 RX-3
1976 - 1978 COSMO
1974 - 1978 RX-4
1977 - 1981 GLC
1979 - 1980 RX-7
1976 - 1977 MIZER
MERCURY
1975 - 1980 BOBCAT
1982 - 1983 LN7
1971 - 1974 CAPRI
1981 - 1985 LYNX
1976 - 1977 CAPRI
1967 - 1986 MARQUIS
1979 - 1986 CAPRI
1975 - 1980 MONARCH
1965 - 1976 COLONY PARK
1964 - 1968 MONTCLAIR
1979 - 1982 COLONY PARK
1968 - 1976 MONTEGO
1984 - 1990 COLONY PARK
1968 - 1974 MONTEREY
1965 - 1969 COMET
1964 - 1968 PARK LANE
1971 - 1977 COMET
1968 PARKLANE
1967 - 1982 COUGAR
1984 - 1985 TOPAZ
1975 - 1990 GRAND MARQUIS
1978 - 1983 ZEPHYR
MITSUBISHI
1983 - 1986 MIGHTY MAX
NISSAN
1977 - 1981 200SX
1974 - 1977 710
1973 - 1976 610
1977 - 1981 810
1975 - 1979 620
1974 - 1978 B210
1972 - 1974 620 PICKUP
PEUGEOT
1977 - 1979 604
1982 604
PLYMOUTH
1976 - 1980 ARROW
1978 - 1979 HORIZON
1979 - 1982 ARROW PICKUP
1978 - 1983 SAPPORO
1979 CARAVELLE
1974 - 1976 SCAMP
1979 - 1982 CHAMP
1983 SCAMP
1983 - 1984 COLT
1974 - 1976 VALIANT
1984 CONQUEST
1976 - 1979 VOLARE
PORSCHE
1971 - 1976 911
1970 - 1976 914
1976 912
1979 - 1980 924
SUBARU
1978 - 1981 BRAT
1972 - 1975 GL
1972 - 1973 DELUXE
1979 - 1981 GL
1974 - 1981 DL
1980 - 1981 GLF
1979 FE
1977 - 1981 STANDARD
1975 - 1979 GF
1972 STAR
TOYOTA
1972 - 1973 CARINA
1978 - 1980 CRESSIDA
1971 - 1977 CELICA
1969 - 1980 LAND CRUISER
1968 - 1979 COROLLA
1970 - 1978 PICKUP
1968 - 1978 CORONA
HTH
:cheers:
Lou
