odometer??
San Jose CA
so, my odometer wasn't turning. I tried to remove the cluster...with the usual problems. I finally got the cluster out, and proceeded to modify a few things to make it easier to remove next time. I ground down the lower two tabs a bit, and notched the upper part of the dash right where the speedo cable bumps it. Now the cluster comes right out without jamming my big hands in to unclip the speedo cable.
After all this, and carefully reclipping the speedo cable, only the 'tenths' wheel moves.
Any helpful suggestions? I probably will try to rebuild the odometer, but ...
If I take the tranny end of the cable and put it in a drill to test the cable integrity, which direction should it turn? And if I get it backwards will it screw anything up?
Can you drive with cluster removed and see if you can see the cable drive spinning? This tells you direction and helps to narrow down where the problem is. Good luck.
If even one wheel is turning there is nothing wrong with cable.
Sounds like it's an internal speedo issue.
The OEM grease in them drys out and cakes up...probably just needs a decent cleaning.
See thread:
^^^ used the thread that @JohnnyC included and got mine clicking along.... Occasionally, some of the digits quit moving so I keep a screwdriver handy, remove just the cluster retaining screws and sorta ‘bump’ it against the dash (sometimes while driving :hillbilly:) to get it moving again!
