Oddometer
kenya
Hi Guys,
Just did a small trip down to Northern Tanzania from my home in Kenya.
1994 LC VX80 4.2l TD
The odometer was reading 171,950kms.
When it reached 171,999 it ceased to function along with the trip meter.
Any ideas?
Are they driven by a cable?
Cheers
Mike
I too own a 94, now i don't know about the overseas models like yours, but IIRC the one's delivered here in North America use an electric transducer mounted on the transmission/transfer case that sends a signal to the speed O. Could it be that your having a problem with that transducer, causing your speed o to stop working? It might be worth your time to climb under your truck, to make sure that transducer is still connected up.
Thanks for the imput Rifleman but I find it too coincidental that it stops working on the 171999 changeover.
Sounds more like the dash board end.
Will check under though.
Cheers
Mike
my 93 has had 2 speedos go out and my 94 1. the PCB on the back goes out. would be something else to check if you dont find a simple fix.
My 96 had an issue that the Trip odometer broke and wedged a piece of a tooth on the main odometer causing it to stop.
I poked the trip odometer about 100 times off and on while driving and it cleared the piece. My main odometer works now, but my trip odometer is still broke.
Otherwise, yes I'll bet it is in the gears inside the gauge cluster. Get a replacement in hand before you tear apart the old one.
Thought I might try reversing for a kilometer or so to see if it comes unstuck.
Jacked all wheels up and put it in reverse. Nothing happened.
I mean the wheels did not turn at all. ?????
For the benefit of others who may arrive at this thread in the years to come.
I removed the dash and applied a little compressed at to the back of the speedo. Working again perfectly.
Thanks for all others advice.
My odometer wasn't working when I got my 93 with 245k miles, Teeth were broken. PO had been driving it for over a year like that. Had to replace the speedometer portion of my cluster with one from a donor.
