ODB Fusion
Does the OBD Fusion app (with the Carista or similar OBD2 bluetooth adapter) read and reset ABS codes on a 2002 100-series?
I know the LE Link will read and reset codes. Just did it an hour ago with a MAF sensor code I got when I forgot to reattach the cable after replacing air filter and adding air filter service gauge to the air intake housing.
I'm amped you posted this, I've been wanting to run something like this on my iPhone without killing my connection to the outside world, this is perfect. Thank you.
No worries. Yeah I started off with a wifi device and quickly returned it for the bluetooth device so I can keep my LTE.
Got it set up yesterday - painless!
Adding this to my portable TIS system means I've got my bases covered. Love it.
If anyone is looking for Trans Temp I'm getting results and what look like valid results with these:
Name = Transmission Fluid Temperature 1
Description = Trans 1
English units = F
Min value = 0
Max value = 300
Metric to English scale factor = 1
Module/Header = ECM
OBD Mode = 21
PID Number = D9
Equation = ((((E*256)+F)/256)-40)*1.8+32 this for pan temp. and
This for converter temp.((((G*256)+H)/256)-40)*1.8+32
Those will give you outputs in deg F.
Located them here and assumed the Tacoma formulas would work.
Obd fusion trans temp 2006
English units = F
Min value = 0
Max value = 300
Module/Header = ECM
OBD Mode = 21
PID Number = D9
What year is your cruiser?
I tried this on my 2000 and can't get it to work.
I just got my LELink and downloaded "OBD Fusion" ($9.99) onto my iPad (+ the Toyota Enhanced Diagnostics 2007; $9.99)
Plug and play.
Everything seems to be there (incl. ATF temperature).
It's awesome!
Thanks everybody for this thread.
I would like to revive this thread.
As stated above, I use the Link and the Fusion app. I love it! There is a lot of stuff that you can check and continuously monitor while driving using the Dashboard.
How about we exchange information on what is useful to monitor and what is the correct PID for it.
Right now I am configuring my Dashboard (in the app) and wonder what to monitor.
So far, I have
Page 1
- Engine RPM
- Engine temperature
- Engine Coolant temperature
- A/T Temperature
- MAF pressure (this was in the default setup, I don't really know what to do with it)
- Battery charge
Page 2
- Fuel gal/hrs
- inst. fuel economy
- overall fuel economy
- Distance to go
- Fuel gal. left
I would like to monitor Oil pressure as well, but can't find the PID.
What else is useful?
[The oil pressure gage in the first picture is a placeholder until I find the correct PID. And the Fuel Pressure and Fuel Temperature in the second picture are not confirmed correct. The PID I used was for Fuel Rail Pressure A and Fuel Rail Temperature A.]
Has anyone gotten AHC pressure readings working using OBD Fusion?
So far, I have
Page 1
- Engine RPM
- A/T Temperature
- Battery charge
Page 2
- Fuel gal/hrs
- Distance to go
- Fuel gal. left
So far, I have
Page 1
- Engine RPM
- A/T Temperature
- Battery charge
Page 2
- Fuel gal/hrs
- Distance to go
- Fuel gal. left
Any updates on Oil Pressure PID?
