O2 Sensor bypass question…
So, to put rock sliders on my 96 LX450 (35s/529 gears) I had to cut out the cats and replace it w a straight pipe. The rear part of the pipe w the downstream O2 sensor was also cut out. So, there is no rear sensor just an empty plug. Obviously the check engine light is on. I’m worried that it may be running to rich because that’s the default setting when the O2 sensors aren’t working. So, I’m worried about fuel consumption and carbon buildup. Otherwise, it currently runs well. Has good response and doesn’t smoke.
Options to fix the issue if I don’t want to replace the cats and get new pipes?
What will happen if I simply get a down stream sensor and leave it open to air? Will it run too lean?
Should I clear the code and see if there are any changes in performance? And, if not leave it alone since it’s not running too rich?
Let it run rich and use some Sea Foam or MMO to clean out the carbon buildup?
From my in line search…
I can buy a new down stream sensor and increase the resistance of going from the sensor to the computer (picture). However, I don’t have a place on the exhaust pipe to plug in the sensor since it was cut out. So, the sensor will be open to air.
I can also purchase a simulator. But, I still don’t have a way to plug the sensor into the pipes
Any thoughts?
Any thoughts?
