Land Speeder
InstaH8R
- Thread starter
- #101
BTW... I installed LAST WEEK! That happened in literally like 3 days...
Got them Slee Castor Plates:
BECAUSE the blue bushings did this in less than a week:
Luckily I still had a set of arms with the OEM bushings to use the plates.
Huge thanks to @Intern22 for his garage this morning! Hopefully he'll get that lift sooner than later and I can help him!
Same thing happened to mine. I don't think my rear rotors got worn like yours but the pads got worn down so far that all was left was the pad backing plate. The backing plate got pulled between the small slot between the rotor and caliper bracket. Mine was undriveable because the friction surface on the rotor got cracked and the caliper piston kept on catching the edge of the piston.And another "oh yeah..."
last week, went to get my dinner and heard a gawd-awful grinding. Like two midgets in the backseat scrubbing!
backed up outta my spot when leaving and the rear locked up. I Immediately knew what the issue was. limped home. Ordered rear rotors and pads for in-store pickup and texted my mechanic friend. He said he'd throw them on the next morning.
Here's the damage: a stuck "single piston" design... was psuhing on one side, prolly for years... the pad got so small, it fell out and into the wheel. I've seen this before on the rear 80-series single piston calipers. a slide-rail gets seized...
And BTW @Intern22, it was definitely the shocks limiting the droop when trying to put the 2" spacer in.... OOPS!
Next up is sway bar drops and bump stop drops! Gotta fab them up with some 2x2 and 2x3 tubing...
