ntsaint's FJ40 search and build
Yes. Make sure you remove any dirt, grease and brake fluid before spraying. Use a name brand brake caliper paint and you will be fine. After it dries go and drive it so the calipers can go through a heat cycle and it will bake the paint on.
I would use black or red caliper paint. Stay away from the yellow and silver
Put both the 100 and the 200 in the garage today. Only the 40 in the shop. Time to get back to work.
Nothing wrong with Warn hubs. Rock em.
Just out of curiosity, are you going to weld up the extra antena hole on the driver side cowl panel?
Stacy Robert's truck is running them, I ran them for years. Say what you want. There are a s*** ton of them on the trail. If you've got Aisin's then run them but if not then fix it when it breaks. Never seen one break in all of my wheeling. I'll probably get some smart ass comments but the only hubs I've ever seen broken were Aisins. Jrobs most recently.
Most of y'all trucks need drive flanges since they don't see much street time. JRobs especially.
The warrens will definitely work in this case, though the Aisins can be argued will have more street cred with the Toyota crowd. Did 40's ever come with those though?
Maybe the later 40's did but both of the 40's I have had (74 and 78) had dealer installed lock out hubs.
