- Joined
- Feb 26, 2015
- Threads
- 7
- Messages
- 64
I have another thread on here.Problem still there! I've changed fuel pressure regulator, Mass Air Flow Meter, spark plugs wires and distributor cap, also rotor. Even changed fuel filter. After truck has been run for a while then shut off for a bit it will try to start then spit and sputter and cut off! Does not have a lot of power when driving too. Driving me nuts! Cel comes on when key is turned. No cel when running. So no code thrown. Its a 1991 with stock 3fe. 111,000 miles. Other then the restart issue sometimes it has no other signs! Idles good runs smooth. I have a fuel pressure gauge on it now. Running is 30 psi. Right after cut off goes to 40 psi. When it acts up pressure drops to 20 psi and slowly drops as I turn it over. If I release the pressure on the line with the gauge it starts right up....? Anyone have any thoughts? Thanks alot! About ready to sell it.
