Slightly about half is probably in the 210 range. The gauge is more or less worthless, tons of slop in the middle.
Is it better to do a coolant flush or is drain and fill ok? The price isn't that much more to just have the dealer do a flush.
Flushing any part of the system whether it's oil, tranny, coolant, etc... always makes me nervous. I think the FSM just recommends a drain and fill. I would stick to the Mr. T service methods.
Let us know how it effects your temps.
It recommends a flush.
Just stumbled across this and thought I'd chime in....
1999 LX470 with 247k. New radiator/hoses/Ts/T hoses/coolant flush with new Toyota red....
Driving from Seattle to Bend, OR outside temps hit 99F and driving over mountain passes at 70mph it would occasionally hit 203 on torque pro app, as well as hit 203 idling in traffic.
I was worried about it but after reading this post maybe I shouldn't worry. For the majority of the 300 mile trip I was running at 195ish.
My new radiator didn't come with the foam either which probably helps a lot.
How is your radiator cap, thermostat, and fan clutch? Those can all contribute to running slightly warmer than normal.
New radiator cap as well. Fan clutch was replaced by prior owner within last 50k. Only thing I didn't replace was thermostat because I couldn't find it when I had the radiator done. I had the part just couldn't find it. It was also replaced at the dealer in the last 75k miles.
Do thermostats go bad that often? Or is it just something people do because it's easy?
I forget the service life on a thermostat, but they can fail. Do you know if they used a OEM or aftermarket? Personally, I have compared OEM versus aftermarket thermostats and the aftermarket units ran several degrees warmer than OEM. If you are unsure of the status of the thermostat, I'd pick up a OEM unit and install.
Well, I hope they used OEM, but I have read plenty of stories here about folks having work done at the dealer only to later find out they did not use OEM parts.I have an OEM thermostat in my glovebox. I'll put it in when I get back home. But pretty sure all parts were OEM since they were done at the dealer. The only non-oem part is the radiator (koyorad) which I just installed a few weeks ago because the OEM radiator was leaking.
Also, I'd get some foam to install around the radiator to help seal it up.
Which company did you purchase the koyo radiator from? I’ve having trouble finding anyone that carries koyo, locally.I have an OEM thermostat in my glovebox. I'll put it in when I get back home. But pretty sure all parts were OEM since they were done at the dealer. The only non-oem part is the radiator (koyorad) which I just installed a few weeks ago because the OEM radiator was leaking.
