Non-USA 4spd.
coiled40gary said:
I think the answer to your question is no. The H41 and H42 are the same length, but the H41 is fatter to accomodate the larger gear. I had to bend the shifter linkage a little because it was contacting the side of the H41 before fully engaging.
gary
That figures, I was hoping it was nothing more than a gear swap. Thanks.......
To all those who want the trannies, I have pulled them from the corner of the shed [this is my workshop] looked at them and found that most of them are incomplete (all of them have been pulled apart for measurements, though all the parts are there). However i am sure that if you have the know how to rebuild then they are perfect for want you want. There are three with 16 spline output shafts, 2 with 19 spline output shafts, 2 with no output shafts. 3 transfer cases, one a split transfer and the other 2 onepiece with vaccuum change on one (most of the parts are there). All output shafts are worn and some have had water in them at some stage with some surface rust. All the gears must be good to someone but if you mention 4 speed in australia it is rubbish because everyone wants 5 speeds here. As I say they are a basic gearbox with a lot of tolerance that would only need a bearing kit. A press and a bearing puller is all you need and of course a clean box is a good box and these can be cleaned up easily. Now the other thing that I am concerned about is the weight of this whole package, it could be 500kg as i can make a crate to carry it all as I have lot of board hanging around unless someone has any other suggestions (possible separate???). As I said earlier in this post, I don't want money for them, I just don't have a need for them but I am chasing pentronix point conversion kit set with matching coil in exchange for them. Anyone who is interested, pls send me a private message. First in bessed dressed, or if I don't hear from anyone in a few days, I will get rid of them over here.
Cheers
Nick
The bubble pops.
Nick, save the top covers at least. When SOR sells one they don't include a top cover with the shifter mechanism. There's no core requirement so a buyer uses his own H42 top cover which fits and works fine. I don't know why SOR doesn't include a shifting top cover.
So if that SOR H41 buyer wants to use his take-out H42 for another vehicle, maybe as a conversion from a 3 speed, he is left with no way to shift the transmission and has to hunt up another cover/shifter for it.
As far as no top cover, it saves on shipping on most transmissions in my experience as it allows UPS. On a side note, Perth is about as far away as physically possible from the US and lacks affordable shipping methods as outgoing tends to be Sydney, Brisbane, or Melbourne as they are on the east coast. Shortest distance between two points etc.....
honk said:
?? They're both toploaders.
Yes, they are, I used the shifter and top plate from my H42. The shifter linkage I had to bend was the t-case shifter that runs down the side of the tranny. While on Rubithon 2000, I was talking with Mudrak about a strange sound that was coming from my t-case when I got up into 3rd and 4th gears in low range. He said the low range was not fully engaging. Following up on that bit of info when I got home, I discovered that the shifter contacted the side of the H41 about the same time as it engaged low range. After a little heating and bending, I saw I could move the engagement a little further, and the strange noise went away :-). The shifter linkage did not contact the H42 as the H42 does not have the bulge in the side that the H41 has.
And I just dug out my old SOR receipt on the H41. It was $750 with a $50 core charge. Which I thought was silly, because it would have cost me $100 in shipping to get $50 back. Not to mention giving up a perfectly good tranny.
gary
USD$300-400 new, $100-200 used? that's a rough guess without doing a lot of bargain shopping.. usually you can call up a shop and they might have something in good shape that works for a person
