Does a non e-locker 3rd bolt into a front e-locker housing?
Nope. They are completely different. I don't think you could even modify it to work.
But I read in the Slee site that it's posible modify a non locker housing to fir a e-lock 3rd ..
Yes, this is a true statement. But it's harder to go backwards.
Actually...
It can be done, but I wouldn't do it for a long term thing. I've done it (took an e-locker out of a Tacoma and put a non-locked open diff in), and it worked fine, no leaks. I did drill and tap a couple of new holes just to be on the safe side, stuck bolts in them.
Ok, good enough. I can remove the knuckles from an e-locker'd 80 and put them on a non to gain the larger rotors/calipers, correct?
maybe Dan's old.
Early 80 non e-locker vs. e-locker
Early 80 brakes to FZJ brakes is what I want....buying complete minus 3rd e-locker, what do I need to swap?
Can't just use the backing plate?
