Only at low speed. Maybe coming from the rear? Just not sure. I don't see any thing wrong.
Mine is making a similar sound, just not quite as loud. It increases/decreases w/speed but can't hear it above about 15-20mph. I have new u-joints w/in 10K miles. I have no idea what it is. Sounds like a zip tie straped to my d-shaft.
Yes, I'll bet U-Joints with a SLIGHT possibility of slip yoke. Get under the truck and check the DS with the drive line UNLOADED (Meaning: Set the E- Brake, leave it in neutral, chock the wheels) then get under it and grab the DS and try to rotate and slide side to side and up and down.
Another possibility would be the rear pinion bearing loose and and the flange is contacting the seal body. Use the same procedure there to feel the "looseness" of the pinion. Also when you twist the DS, the DS should NOT move in or out of the rear diff when doing so. If it does, the pinion bearings are out.
Since you will have it out, I would do both ends just to save time later. Sometimes having run out of balance like that for a long time can damage the one on the opposite end. But I overdo PM anyway.......
