No Vacuum pressure
Florida
Fellow LCer's
An issue has come up that I believed was a timing issue, but has turned out to be a Vacuum (or lack there of) issue. Searched the FJ40 forum found 3 pages, but did not see similar issues. Below is the assessment.
The Testing and Symptoms:
  1. Compression at all cylinders 148 - 150.
  2. Timing set on the BB with Vacuum disconnected. Dwell 44
  3. Connected and ran vacuum gauge to Brake Booster hose off of the Intake manifold. Reading is 5 (that is the red zone indicating Late Valve Timing, or leak at Intake Manifold or Heat Riser). Normal zone is 17 - 22 HG. Oh crap. After driving, I stop the engine, pull the vacuum hose off the brake booster, and no pressure at all.
  4. Cannot drive over 55 before backfire through carb
  5. Difficult to start after stopping
  6. Fuel-pump produces 6Lbs
  7. I see no signs of leaks or cracks on the Intake manifold (removed it). Will magniflux (think that is the process) find a crack?. Or leaks around the gasket. I did see oil sitting in the Intake ports which I am sure is producing the black smoke out the exhaust (oh crap again). I did replace the black seals around the valve guides.
I am looking for ideas. The motor itself was gone through (new pistons, head re-surfaced, valves and guides done). Idle is incredibly smooth.
  • My thoughts were leaks around the carb, but that was de funked with the either test (that is scary).
  • The other thought was the exhaust and intake are not seating together properly, but that would show some signs of leaks. Still my focus. Maybe remove header and intake to be re-surfaced.
  • Had the "can't go over 55 issue" before but that was resolved with a new distributor.
Can I get some thoughts here? thank you.
Boaf
Don’t recall is this a vacuum actuated FD or mechanical?
Fellow LCer's
  1. Connected and ran vacuum gauge to Brake Booster hose off of the Intake manifold. Reading is 5 (that is the red zone indicating Late Valve Timing, or leak at Intake Manifold or Heat Riser). Normal zone is 17 - 22 HG. Oh crap. After driving, I stop the engine, pull the vacuum hose off the brake booster, and no pressure at all.
Boaf
if the engine is not running, you will have no vacuum...like as soon as the engine stops rotating there will be no vac.
i would question the condition of your vacuum gauge. the differnce between compression and vacuum numbers is too great. i doubt it would even run, let alone be drivable with only 5inches of vacuum.
Fair question Brian.
Engine running, little to no Vacuum. Brand new gauge Pittsburgh Automotive.
About 6 months ago, I had purchased and tested the vacuum had 15 inches, so something has changed.
Boaf
The distributor has a mechanical advance (counter weights) and a vacuum connected to the carb.
Boaf
Transfercase....vacuum op or shifter through the hump?
^2 Yeah was just adding the check of the vacuum connection and system to the transfer case (if that’s what you have) to your check list. If you do have the vacuum transfer it gets it’s vacuum from the intake side which is the side you checked and was low (if accurate).
Yep, no vacuum to the transfer case for me. Good ole 3 speed.
Carb cleaner sprayed around the manifold and carb will detect a vacuum leak. If a leak is present, your idle will increase.
Magnaflux is for ferrous (iron) auto parts.
The Pittsburgh vac tool got taken to the trash by an other Mudder earlier this year. I'd start a thread reviewing bad and not bad tool choices, but, one unfactual statement holds one libel, and I'm about keeping life simple.
The fuel pressure is X2 or X3 greater than recommended.
The header is my second guess. Who manufactured it?
You didn’t say...
1. Did you hook vacuum back up to the dissy? Or, at least cap the dissy and carb ports?
2. have you tested the booster for a vacuum leak?
3. black smoke and carb backfire can indicate you’re running way too rich... have you tried “starting over”, with the “lean drop method”?
You said... “After driving, I stop the engine, pull the vacuum hose off the brake booster, and no pressure at all.”.
You realize, “stopping the engine” eliminates vacuum, right? The engine only produces vacuum while it’s running.
While idling, spray carb cleaner everywhere there is a vacuum hose, vacuum port (including dissy, booster, carb) and spray where the manifolds/headers mate together and where they mate to the head.
Listen for an idle increase, to indicate the carb cleaner is temporarily “plugging” a vacuum leak.
Headers came with the Previous Owner. That too is my very sneaky suspicion.
You didn’t say...
Very methodical. Header is leaking, going to replace it. Yes, understand no vacuum when the engine stops. There should be some residual Vacuum in the brake booster, always has been until now. Thinking JT header. Any thoughts?
Boaf
Boaf
One more note: I did remove the Intake Manifold. I see oil in the intake ports. Not sure that is normal (is it?).
Yes, it is running rich, and ordered a fuel pressure regulator for my 3 PSI Weber 38 / 38. I tuned the Weber down at one point to 1/4 turn on each adjuster. Still getting too much fuel, hence the pressure regulator to dial down from 6 to 3.
I want to replace that header. The PO really butchered the truck, but that is the challenge :).
@Pin_Head, your weigh in?
The header that came with my truck was 13/32 inches (.406 inches) plate at the flange, if I remember correctly. The 2F intake manifold is pretty much 10mm (.394). That means that the intake will be subject to leak, and the header is tight. It appeared to have intake leaks when I disassembled it (oil between across the head manifold gasket). So, when I got an Aussie Performance Header to replace it (which routes under the gear box skid plate and needs to be modified / grinded to not interfere with the 2F heat shield) they sourced 10mm plate at the flange, and I didn't need to do anything beyond the what is called for in the service manual for an install. Some people suggest making split washers for the thicker header flanges, but the .012 step thickness makes for more machining, and the washer must not spin upon install, but it is a simpler solution that doesn't require permanent modifications. One of the header makers on Mud suggests using Copper Coat lacquer based liquid sealant on the manifold, both sides of the gasket, and the header and intake. It bakes on, and is a big scraping job to remove, but will save you from paying at the machine shop.
I bought an F intake off of Ebay, it is beautifully uncracked, but a PO buggered up all the faces where the washers and nuts tighten so that they are no longer flat, and they are varying thicknesses. This would be a good candidate to have machined minimally to restore flatness at that location, and use step washers. However, as a former professional machinist, getting a ridgid tool that does not interfere with the main plenum from the side opposite the engine is going to be tricky, and time consuming.
My advise is to have have a micrometer or calipers handy if you disassemble, that way you can see what the dimensional challenges might be with your current set-up. I also have the proper re-threading die, so that I could resolve any buggered up threads on the head studs, and achieve proper torque specs with the help of the lubricant in the packet of high temp anti-sieze. Also, get a good, fresh gasket.
The die probably has to be hexagonal so you can turn it with a regular wrench without interference from adjacent studs. This is the proper size and pitch for OE studs on a 2F head.
It is not.
Valve stem seals are worn.
It is not.
The ding a ling I had the head sent to said they were tight. Fricken rookie, new he was not trust worthy when he took so long to do it. That makes the rest of his work suspect.
Thanks.
can improperly Adjusted valves cause these symptoms ?
for example if the PO or cylinder head mechanic simply set them too w/ too much gap , hence affecting the Duration of open and close ?
should simple Valve adjustment verifies spot check be be done here ?
or the Dist. was set 180' degrees Out , then all fine tuning was done to that
over-site ?
i personally had a Columbia spec. import dropped off at my shop right from the Boat , Port of Baltimore ,
the dizzy was indeed installed 180' out , and everything was all F'd up
in Oder to compensate and correct for that
some of this maybe a stretch , but a 180 out diizy was a Fact for me , low Vacuum too was a symptom .....
hope this helps out in some way
over-site ?
All valves were set to spec and checked just 5 days ago just to confirm they were spot on (008, 014). The truck runs great under 40. Beyond that....not so much. The advance is not working.
