Hello all!! I am new to the community. I freaking love my 2000 LC and am saving money to do some of the cool mods i see other people making on here. I have been reviewing the FAQs and other posts and have learned….hopefully…a good bit about crank-no start issues experienced by others in this forum. However I have some unique symptoms I would like to check with the group about. My LC100 has 197K miles and is not used a daily driver. It is mostly used on the weekends to run short errands. Life got in the way and i went 3 weeks without starting the truck which i know is no good.
I had some weird things happen when i finally tried to start it this weekend.
First off, i went to unlock the truck with the “key fob” buttons and my fob battery was dead. Instead of replacing the battery in the fob, I went ahead and unlocked the car with my key and proceeded to turn the key to start the truck. 1st try was a strong crank with no start. 2nd try was a strong crank, but i noticed the smell of something (plastic, wire, other) burning and smoke coming from the drivers side air vent next to the door. 3rd try was strong crank with some smoke and a buzzing sound coming from the engine bay. Subsequent tries yielded a strong crank with no start, smell, buzzing, or smoke.
Next, I started looking for burned stuff. Nothing looked torched at the ECU in the engine bay. There are what seems like a million wires and connectors on the driver side at the floor. Couldn’t see any apparent burn marks there either.
I bought the truck a year ago and didn’t know how old the battery was so i replaced it. The first time I tried to start after installing the new battery, I got the burning smell and smoke coming out of the dash above the steering wheel. After that, I have not gotten any smoke, buzzing or burning smell in subsequent starting attempts
The burning smell and smoke bothered me but, since its a crank-no start condition, I decided to walk through the Air/Spark/fuel process.
I started reviewing the threads here and went through the immobilizer test process. FYI immobilizer light does not flash when trying to start. I even performed the terminal block F to battery + terminal for an extra check.
I jumpered across the terminalsl on the starter relay to check it.
I am assuming since I am getting a strong crank that my spark is good.
So I wondered if the fuel pump had seized up due to age and lack of use. Maybe the burning had something to do with a failed pump??? I was building a cart in partsouq, and thought that i would check with the experts on here before i invested in $500 parts to replace the pump.
Is there a way to test the fuel pump to rule it in/out?
I can’t help but think that something got burned and damaged during cranking. Maybe some kind of overload? I am worried it could be some random wire in that huge loom of wires on the driver side on the floor. Seems like it could be a needle in a haystack situation.
I appreciate your patience in reading the long description, but I feel like the detail is necessary to convey the sequence of events and symptoms.
I appreciate any thoughts
