ask her if something stinks
check the valves if you didnt already
Dan,
Any update on the problem with your daughter's truck?
My daughter has an 86 with 22re and she is describing to me similar symptoms with her truck. Starts and runs very rough when cold or during wet weather. The engine seems to barely have enough power to get the truck rolling. Once it warms up, it is much better - might not be 100% but much better. The problem started a couple weeks ago but it is intermittent. Does not always happen, but when it does, the truck is cold, or weather is wet.
300 miles away beats me. Kate's got the truck about 1000 miles away from me!![]()
Hey Dan, I ended up making the drive to have a look at ours and the problem looks like a blown head gasket or cracked head. Its blowing steam out the tailpipe and pressurizing the cooling system. I'm pretty sure it runs rough at startup because as it sits, water is collecting in one or more cylinders.
I trailered it back home and should have time to start taking it apart within the next couple weeks so I should find out more then. My daughter is now driving another car - '88 Land Cruiser.
I know this probabaly doesn't help you, just thought I'd let folks know what was up with this 22RE "running rough at startup".
DanI replaced the Timing Chain and guides pretty recently (Maybe 5,000 miles ago).
I'll have to make a special trip to do any real checking of it myself, but Kate is pretty handy (hey, she replaced the fuel filter on it in an airport parking lot once). But she doesn't have a timing light, although we may have to go borrow one or something.
I can't even bring one over. No use for the things. Stupid gas engines.
Hilux: oh, I've looked all over for the D-port. I've even checked for other year ports in case somebody hacked a different year harness into that truck. It simply appears to have been removed. Why you would remove one, I have no idea.
Heck, I spent a few extra days when I wired the faux-lux to make sure my OBD port worked...
Dan
It did get fixed, but I no longer remember what did it.
I think it might have been when I cleaned the MAF, and the EGR system real well.
Dan
