Tools R Us said:
Tire Rack (tirerack.com) also has authorized retailers that they will ship toRookie2 said:If you get them on line, any ideas about how you'd go about getting them mounted and balanced? I quess you have to work through a local tire shop. After their mounted and balanced, is there anything to future rotations.... i.e. do they have to be rebalanced when you put them on a different hub and axle? If not, I could rotate them myself.
Thanks,
Rookie2
roncruiser said:You'll like the Revo's as a DD. When and if you go off-road, they are more than enough tire for you. Anymore aggressive tread and road noise enters the picture.
It's a good solid tire and I use it on my DD. Have put a good 15K miles and still going strong. Put a good 5K miles over the course of 3 weeks of mixed on/off road. They've carried me over the hills and through the woods. I can send you pics of where they've taken me. Here's more information:
https://forum.ih8mud.com/showthread.php?t=29035
cruiser4life said:IMO, if you're only going to be driving on the road, you like the Michelins except for the size and want bigger tires, move up a size in the LTX's to the 285/75r16.
If you do decide to do some light offroading, most likely the LTX's will be OK but certainly not a A/T or M/T. You're not going to beat the street manners of the LTX's in this comparison. The only drawback is $$ - they are pretty expensive and with the next size up you're looking at north of $200 per tire out the door.
On the other hand, I can't speak to the Revo's but have NTG's and really, really like them. I'll be buying more. Road manners are fine, perform well in snow, mud, rocks, etc. and are very inexpensive. I just bought a spare last week in 295/75r16 and I paid $120 mounted and out the door. Don't know about their longevity (haven't had them that long) but I've heard it's more than adequate.
alia176 said:Since your priorities are like most of us, on road driving, I'd suggest either Revos or Geolander AT II+. I have a set of Geos, so if you wanna meet up and check them out, let me know.
For the wheeling that I do in this area, the Geos do a decent job. The side lugs are large enough to get me through most muddy obstacles I encounter. Road manners are very nice with a slight noise at higher speeds but nothing like the MT/Rs I had previously. I have a set of 315s and they balance nicely. These tires have gone through Moab and some CO w/o any rips or tears. They don't cup at all but I rotate them quite often at Discount Tires. They matched tirerack price of $125/each when I purchased them two years ago.
Ali
As an option, you can buy the tires online and then bring them to your nearest GSP9700 shop. Though it may not be necessary. It seems as if most people don't have any problems mounting either the Nitto nor the Revo.Rookie2 said:If you get them on line, any ideas about how you'd go about getting them mounted and balanced? I quess you have to work through a local tire shop. After their mounted and balanced, is there anything to future rotations.... i.e. do they have to be rebalanced when you put them on a different hub and axle? If not, I could rotate them myself.
Consumer Reports also rated the Geolander AT+II with near identical ratings to the Revos with the exception of snow traction and ice braking (Geo received poor ratings). Do you concur?chitown40 said:2nd that. I've had the Geolandars for about 2 months now, and they are as good as the Revos or better. The tread depth is significantly greater, the road noise is similar, and the handling (wet and dry) is as good as the Revos. I've even owned Revos before so I do have something to compare them to.![]()
alaskacruiser said:Whoever said the Revos are like the Michelins has never spent a significant amount of time on and off-road in a rig with Revos. The Revo is an excellent do-it-all A/T in that it has excellent on-road performance, and it can handle moderate trails very well- sidwwalls have held up fine for me even on some pretty sharp rocks. Make sure to get the 285s for the D load rating and thicker sidewalls. I've put 30k on mine and they have worn very little.
Do not judge a tire because it "looks" the same at first (cursory) glance as tucker74 implies in his post. If you're going to analyze a tire that way, might as well go with those wooden wagon wheels.
Seriously, though, look at ratings on http://tirerack.com and talk to people with experience with both tires. I'd go with the Revos, myself.
