- Joined
- Oct 27, 2003
- Threads
- 30
- Messages
- 475
The Downey mount only goes back into the frame 1.25 to 1.5", your frame is cut back atleast 2". You could weld-in a scab plate behind the Downey mount.
Also look at my P.S. Hose Kit, hoses make an immediate rearward turn and just skim over the top of the frame--below your grille panel.
You could use the larger diameter of my steering shaft on the bottom, and the actual length of the larger O.D. (slip-yoke portion) is trim'able to any length you desire (shorter or longer).
The downey hose kit make a nice instalation. I am glad to see they are still available!
In the event someone pries this truck from my cold dead hands, and wants to try and make it original again, I'm trying not to tear it up any worse...
