Newer style seat gears? (1 piece plastic vs brass)
I agree with @NLXTACY, a brass gear against a plastic worm is a bad idea. I doubt it'll wear the worm, but it is a waste of money. What I have been working on is a bronze (not brass) ACME screw end bearing, to replace the far end plastic ACME screw retainer, held in place by two screws into the plastic. Number 1 son's power seats were wobbly, so we took them apart and I noticed that the ACME nut and the far end plastic bearing were both worn.
Unfortunately, both parts are components of the seat track assembly, and aren't listed as separate components (and aren't available anyway). I'm thinking of shimming the rubber on either side of the nut to take up that slack (instead of twisting it, as has been recommended).
The plastic end bearing can be replaced with a fender washer (modified with two mounting holes), but that's a little crude for my taste (to each his own). Since the screws are really just small lead screws (with lots of torque on them) and the near ends are supported by the motors, it makes sense that the far ends wobbling around would add to the premature wear of the near end gears (similar to the plastic end caps that keep falling out).
My evil plan is to press (or braze, I haven't decided which yet) a small bronze tube into a bronze plate, with the appropriate mounting holes and shape. My thought is the bronze will wear better against the steel screw than the plastic (which is abrasive and flimsy). It won't be much to make, and certainly a lot cheaper than brass gears. I'll post a picture when I get them fabbed up.
Polymer composite bearings are vastly superior to any red metal alloy when they are used correctly.
If you need your seat adjustment to last 1000 years you should machine up a sealed stainless housing, make everything that moves from hardened and ground toolsteel and flood it with synthetic oil or synthetic grease like Kyodo-Yushi.
Even though we're talking about Land Cruisers here they are still mass produced automobiles. Mild steel on mild steel or plastic is a perfectly acceptable bearing arrangement for a low speed, non-life threatening seat adjustment.
A note on brass gears: They have a small lip leftover from machining on the outside edges that needs to be sanded down to move freely in the metal sleeve/bushing on both ends.
I’m gambling on the brass gears. It’s a stop gap for me until I figure out what aftermarket seats I want to install.
Since you guys are on the seat gear replacement discussion. Did you guys ever replace the 1 plastic washer that is on the seat gear shaft? The one that I just fixed yesterday had one with the consistency of gummy bears, sticky AF, and unusable. I could not find a plastic washer similar, so I made one using my left over Kydex plastic. I just traced the similar size metal washer and cut away. So far so good. I would like to know if you can buy that plastic washer or if anybody have found a similar plastic washer.
A standard garden hose gasket is an exact fit once you trim off the 3 tabs.
The underlying reason for seat gear failure is the 25+ year old grease that Toyota used in the seat gearboxes has now turned to glue. This forces the drive rod against the little plastic plug until it fails, or simply strips out the plastic gears.
I have replaced gears (Gamviti) on 4 80 Series seats. Each gearbox was nearly impossible to move by hand, and the rubber washer had practically dissolved into an unknown sticky substance. Once cleaned out, which took some time BTW, rebuilt with fresh grease and a new washer, the seats move easily in all weather.
What kind of grease did you use and is it still holding up?
Whatever was at the hardware store at the time. Permatex 80345 white lithium grease, but anything similar will work.
The hard part is cleaning out the old crap.
Seats all work perfectly.
I used Sil-Glyde as I had plenty on hand at the time
