Newb from Texas!
Agreed.
Ihasfip: Check out some 80 series Land Cruisers wheeling on Youtube, and see if they are not capable. Not only capable, but comfortable (I get to say this since selling my '66 FJ40). :D
Oh trust me, I have watched alot of them. But, due to the lack of descriptions and my noobness, I can't always tell how much lift or what lift they are running.
It seems with "J"s there is little to nothing to modify except for some caster correction. But does it perform well? Does anyone have a link to a video or pics of something on "J"s doing some wheeling?
D
J's are made for armor. My rig (pictured) rides like **** w/o armor. With armor it sinks maybe 1/2" but rides better again.
These things are tanks. The next mod would be 4.88 to replace the 4.10 so i have my crawl back.
Hmm, well I will have to do some more research I guess. Definately sounds cheaper than the 2000$ OME kit or the 3300$ Slee kit.
True that. I will definately have to invest in some gears shortly after the lift in tires. When going from a Cummins with 6.72 gears to this is quite a step.
D
It is not a DD for me, so I don't care about drive shafts, caster, sway bars, brake lines, yada yada. (just kidding on the brake lines)
You need caster correction and a front CV shaft if you go J's. You WILL kill your front UJoint in about 500 miles if you keep the stock shaft.
It is a great lift for cheap. Springs, shocks, brake lines, caster plates, front CV, and you can run DD easily.
These things are not fast to begin with, so moving from 31 to 35 didn't really affect me much. I noticed on stopping more than accelerating.
Is there an actual kit out there that contains all of this? The DS included?
D
oh, they will want to sell you EVERYTHING. just go into it knowing what you want. By everything, I mean panhards, sway extenders, lower links, front and rear DS and every possible part.
Ask for J's (springs), L's (shocks), 30mm front spacers, slee caster plates, extended brake lines, and a front DC shaft. I have no sways, but if you want to keep them, get sway bar drops.
You said THEY will want to sell me everything. Do you mean Slee? Is panhards not required with J's? I would probably ditch the sways being I typically only drive it 1.5 miles to work one way down residential streets.
D
Ahh, gotcha. Well I guess I have some research ahead of me. Thanks for all the help.
D
Welcome :flipoff2:
There are many here running 37"s and look great IMO. Search here on 'mud you find some pretty sweet setups. 2everest's, Nay's, CreeperSleepers........
I am running J's and L's, 2" MetalTech front spacers & trimmed up fenders and 37x14.50x17 bias Iroks. I actually pulled the spacers out on Sunday and sold them, but I have no pics of how it sits now. Other than that, she is all stock ;)
If I was to do it again, I would set it up just like Nay's rig... That being said, I have no complants and I'm into mine a lot less!
See that s*** it tough looking, and looks like it has been used. I could handle that. I don't know whether or not I am gutsy enough to cut the fenders on it, lol. I did on the big white Chevy...so it is an option. I don't know if I want to go 37s or not. That will require a re-gear for sure. And prolly some upgraded axles/birfs/steering. Right?
I like the stance, and with 35's I wouldn't need to trim, so that may be the way I go.
What kind of bumper is that? And what did you do about your front driveshaft, and caster?
D
