Sorry ..... that was supposed to read MAF, not MAP
MegaSquirt can do it, I'm sure of that. It has provisions to easily use MAP and MAF simultaneously. It could be used to control ignition and fueling while leaving the stock ECU in place for transmission control. I think they even have an add-on tranny controller if you wanted to got that route and pull the stock ECU altogether.
My buddy (his resume includes squeezing an LS motor into a Miata) agrees that the megasquirt would be the way to go. Do you know if anyone has successfully used their tranny controller on the A442F?
Those of you that don't know the context of this song might not find it as funny as some others. But still silly (turn up the volume)
This should be the new required format for all build threads.
As my (very neglected) thread on the 44 falls into that category, I'll go with yes. Grandfathering will apply.That's a lot of pressure. Are current builds somehow grandfathered out of this?
but I've been reading the MAP-ECU3 user manual for the last couple hours, and while I'm no expert, I don't get it. In Intercept Mode (not the optimum setup but a solid easy install for small amounts of boost) MAP-ECU even leaves the flapper style VAF meter in place and calibrates itself to the VAF output. Anything beyond small amounts of boost is no good because the flapper would simply stay open the whole time, so for larger boost the VAF should be eliminated and there is more involved tuning of the MAP sensor for load. Did tuner keep the MAP-ECU3 or do you have it?No. Wanna finish it for me? It runs and drives but not well. Still need to figure out injectors, ecu, fuel pump. I'm hoping to integrate everything with the existing aem boost controller.
So. No update really other than I got burned out on it and started another project.![]()
