I have a TIS system in the truck but also use a small OBDII bluetooth adaptor with OBD Fusion on my iPhone. TIS is obviously more detailed, but OBD Fusion is great for day to day use.
Can you elaborate on your set up to run TIS in the truck?I have a TIS system in the truck but also use a small OBDII bluetooth adaptor with OBD Fusion on my iPhone. TIS is obviously more detailed, but OBD Fusion is great for day to day use.
An interesting note on the transmission temperature. My OBD LX adapter (Bluetooth) lets me see the transmission temperature on my '99, but only when using my newest android phone (which is a year old) with Torque Pro. If I connect to the same adapter with an older android phone (4 years old) running the same version of Torque Pro, the transmission temperature does not read in the app. I do not know why this is, but it is something I have noticed.Also, I believe that in order to read some data w non-tis, there is required software code modification which is way above my pay grade.
Example would be transmission fluid temp. I do not get that w. my 2004 on the cheapo BT interface.
)Just bought the software / cable combo off eBay and then bought a Winbook T700 to run TiS. Nothing fancy, works great - my Toyota master tech buddy was amazed as his personal version was close to $2k, hehe.Can you elaborate on your set up to run TIS in the truck?
Thanks. I have the TiS cable/software and had thought about trying it with a Windows tablet. I am glad to hear it can work.Just bought the software / cable combo off eBay and then bought a Winbook T700 to run TiS. Nothing fancy, works great - my Toyota master tech buddy was amazed as his personal version was close to $2k, hehe.
My '99 holds the long term fuel trims pretty steady (not bouncing around) and quickly changes with throttle input. Generally both banks are running about the same, varying by +/-2 and never going above 5 in any normal situation. When I had a coil pack go out, the affected bank was reading between 6 and 9 on the drive home, while the other bank was reading normal.Those of you are using your OBD2 scanner, I would like for you
to monitor your Long Term Fuel Trims - LTFT1 and LTFT2.
I noticed with my 2002 LX470 that the LTFT1 and LTFT2 will vary
sometimes +/-10. Most times at steady RPMs though it is around 0.
But, on my 2000 Isuzu Trooper LTFT1 and LTFT2 seems to be a
whole lot tighter - I'm guessing the Software responds to changes
in Fuel and Air much quicker.
I'm wondering if this is nothing more than the way Toyota designed
the Software or if I have some sensor that is not functioning quite right.
My scanner does show the MAF varying along with all 4 of the O2 sensors.
Do those bluetooth OBD2 readers draw power when the key is off?
Yes. They are powered by a pin on the OBD port that has a constant hot. That said, I have (accidentally) left mine plugged in for a week without driving and did not notice any issue starting the Cruiser.Do those bluetooth OBD2 readers draw power when the key is off?
