New tc low gear
Suburban Hell
Christo, any update on how your project, mentioned in the above linked thread, is coming along. Any one heard if the Marlin or AA option is moving forward.
The left foot brake tequnique works very well for me. Gotta love the auto in the rocks.
I know that it works, but, wouldn't it be nice to do it all with gear.
It seems like a straight forward way to get a better crawl ratio. Instead of hacking the gas tank and the floor of the rig to get a crawler box to fit.
The brake technique works ok but is a joke compared to crawler gears or a crawler box. The crawler box is the way to go because you don't lose standard low like you do with just the gears. The gears only give you a 25% reduction vs 205% with the box. But most people don't want to hack their truck up to fit a box. Even though it is well worth it.
Wrench,
I like the way the crawler box works, and I think it would be the best option if it were a bolt in application. As it were, I am in the group that has no desire to hack up my rig and gas tank.
Is Slee trying to come up with a box or gears for the stock tc?
I think that Christo is developing an entire plug-and-play xfer with the low gears etc. already insde...
Though there seems to be some confusion on exactly what he is working on...you might want to contact Christo directly as I am sure he is not going to spill the beans on a new product that is not out yet....
I chatted with Marlin last week about a crawler for 80 series Land Cruisers. He shook his head and said he would "like to". I didn't hear anything about prototypes, development or the like.
The best hope is likely Slee Offroad, but if it was easy, it would already be available.
That would be lovely, as would a winning lottery ticket. Personally I don't have the funds for such a project and even though my truck is old and crusty I would never perform the hack job that Chris did on his. Not too much offence intended Chris ;)
With 36" Swampers and 4.56 gears I can pretty much put my truck anywhere I want with all the finesse and of a 300 pound ballerina and have a great time doing it, but that's what makes for horseracing...to each thier own.
I haven't even cracked 90K miles on mine yet. I plan on having it for a good while yet and have no desire to cut metal yet. That is why changing the low output was appealing to me. It is cheaper than a box assuming I do the swap myself. This isn't a mod I'm looking do this week, but in the future I would like to do it.
I never doubted the ability of your rig Jon;)
I read on the other thread that Slee was trying put together a prototype for cm07. Did he succed?
Talk to Chriso directly on Monday. IIRC, the Orion product has been "comming this summer" for the last 5 years.
Didn't mean to come off as arrogant in my last post. Haven't finished my coffee yet.
Worry not man.:) I had 2 cups and a butt already so I'm doing pretty good:flipoff2:
I get annoyed sometimes. If I had a h**p this wouldn't even be a issue, plenty of options. But as it were, I like wheeling a 5000lb wagon.:D Guess I will have to just wait and see.
I just ran UA with the Marks gears in the 100 series (same tx case as the 80, or close). We were running 39" tires and it did make a difference, although not as good as the crawler box. For the money, it is not much change, but it does help.
We (with the help of Gary Waggoner) are working with AA on the Orion box adapter (if we proceed the adapter will be a private label Slee Off-Road product). We are at the point of laying out the money etc etc to do the prototype, however I have my doubts about sales of the unit once completed. I am not sure we will recoup the investment with sales of the adapter once we have them. It will probably be a + $3k solution once you get the adapter, orion, change driveshafts etc etc. It will be the closest to a direct bolt in, but will also have it's drawbacks.
The biggest problem I see is that you will get a 4:1, that will be nice, but you loose your regular high range. Having owned a Jeep in past life with a 4:1 transfercase it is kinda annoying to have super slow or high. AA has to plans to change the Orion to a two speed box.
The Atlas 4 speed would be a better option but the center output for the rear is an issue.
Marks crawler box is about the best solution, but creates issues on install. I think the gas tank can be dealt with better by using a aux tank in the rear as a main tank, rather than cutting the existing tank. Also, you do not have to cut the body if you did a body lift and modify the crossmember.
Couldn't you replace the stock tank with a cell and keep it in the same place for clearance?
I don't mind the cutting and raising of the floor...prefer it to a body lift actually.
I been thinking of a fuel cell instead of my chopped tank. With the box and tank it is really tight under there. Just don't know how to hook it up or what size to get. The aux gas tank in the rear just creates clearance issues. For a rock crawler that's not good.
hmm, I would even consider removing my cargo box in the back and putting a cell back there...they have those ballistic plastic tanks now that are safe inside...hmmm.
Putting such a product on the market is a a gamble... however I think that most people shy away from the 80 has a crawler since it has a lack of support for it when it comes to crawling sloooow. If you bring an option to the table such as a crawler...I believe you will see many more 80 builds out there. Look at the mini trucks...I threw the marlin duel t case setup in my truck and it is literally an entire new ballgame. The nay-sayers have obviously never truly been in the big rocks with the 80...or simply cannot stomach a slight "hacking" here and ther to make things work properly.
A used 80 is actually cheaper to purchase than a 4 runner these days and it is not that much larger of a truck to squeeze through the trails. The runner sells simply because of its huge aftermarket (shared with the mini) and albeit cheaper body panels etc...
Unfortunately it seems like most 80 owners shy away from rock crawling (cant blame them these trucks are just so nice to beat on) But Armor can address many problems like that.
If you build it they will come Slee!
I agree 100%
