New rear led tail lights
Go to your auto parts store and buy a flasher for LED lights. Your orig flasher needs current draw to flash, led's don't draw much current.
Oh Yeah, welcome to mud!
Might make a sig file like mine so people know what year cruiser ya got (top of page under User CP)
i bought some LED tails too, haven't got around to putting them in yet as i am having trouble borrowing a 4 inch hole saw... is this signal thing the only hard part about the install? please enlighten me :cheers:
Welcome!
Electronic Flasher is what you need. It uses a coil (like a relay) instead of a bi-metal filament to switch the circuit on/off. Like Yoda said above it doesn't rely on a high current to work.
Chug,
Where are you mounting your lights? If in the sheetmetal body, just drill a hole and use a metal cutting jig saw to cut the circle. Did your FJ have the round or rectangular tails? Harder to do the recangle ones because of separate T/S and brake lights.
Yoda said:
Chug,
i was thinking about doing that, but because of the way the mounting brackets are i'm not sure it would work out in the end.... you would be able to tell that the circle was badly cut ;p i'm thinking i'll roughly cut a circle and then use a die-grinder to round it out. only problem now is finding somebody with a compressor and a die-grinder :doh:
LED flasher:
http://www.truck-lite.com/webapp/wc...10001&storeId=10001&productId=29236&langId=-1
These are the lights I bought. Mine have the flange, and mount with screws. I was going to install in brackets in orig place, but plans changed (I went with oval lights)
http://www.truck-lite.com/webapp/wc...10001&storeId=10001&productId=29585&langId=-1
You using the rubber grommet? Either the grommet or flange would cover some imperfections. The gommet type needs about a 4.5" hole
I have a die grinder and compressor, but it would be a road trip for ya
i bought grote lights, but i don't think the brackets that came with them are grote... got them from princess auto, not sure if you guys have that down in the US. basically it's like harbor freight (so i've heard) its a metal bracket, but the way it's made i would have to have the larger part of it inside the truck so that the light wouldn't fall out. if i think of it i'll snap some pics
The grommet mount will cover any imperfections up to about 3/16" out of round. You might want to mount them in the cup style brackets so mud doesn't cake to the back of them if you are sticking them down low, if the protrude into the tub then you probably can just get by with the grommet mount alone. There are also bling stainless rings at truck stops and such that can help cover some more of the bracket mounts too.
I always try to start with the hole pretty small and then grind until it's a super tight fit, lots of times you will see trailers and flatbeds going down the road with the lights hanging out by the wires. A LED will last so long you will probably never change it in a trail vehicle, so tight is good IMO ;)
search here for threads by helocat and LED in title and you should come up with some good wiring diagrams and flasher info.
Good luck -
It wouldn't be much work to install the oval LED lights in the factory location, you would probably lose the backup light but just ride the brakes a bit - LEDs are way brighter than your stock lights anyways.
But to answer your question, no sealed LEDs that I know of, you may be able to come up with some bulbs that are LED cluster that replace the factory bulb. You will have flasher/wiring mods to do with either route - very simple ones, but may take away from a resto project.
