So this has happened a few timees in the past month or so....
At a stop sign I will get on the gas from a stop and the 100 will die. It also happens when I get on the gas from a stop and have to stop for a car that was in a blind spot. If you try and crank it back over it wont. I have to wait 10 or 15 min before it will crank over and run good again. I can crank it over and put the gas pedal to the floor and it will stay reving unless i take my foot off and it will die again. Even if i do get it going again it will not really move unless my foot is to the floor. Anyone have any idea what this could be??? Gonna try and barrow my buddies code reader later this evening but would really like to figure out this problem as soon as possible!
Thanks
Thanks
: The OBDII port is just under the lower DS dash panel: Plug the Scan Gauge connector in. Then route the wire under the center console area; velcro the Scan Gauge to the center console area (to the right of the ash tray). Select what data fields you want displayed on the first screen of the Scan Gauge.
