As far as I know I'm the first to fit one of the new '07 AVN navigations into the 80 series. I was told by crutchfield and sounddomain that it would not fit.
They were wrong, it does fit, but just barely. The rear of the AVN fits very tightly against the AC plenum behind the unit, but with some careful wiring everything fits in and the finish when the dash is reassembled is top notch.
I removed the factory amp and ran new wiring behind the glove box for the speakers. I am still using the factory speakers and the sound is still considerably cleaner. I also tapped the VSS wire that is used in the yellow-box speedo correction for pulse-speed on the AVN, and it picked it up correctly. I found the parking break switch signal wire in down in the IG2 connector in the left kick panel (it is red-white) and the AVN also senses that properly.
The one thing I am stumped on is reverse sensing. Does anybody know the proper wire to tap to send a signal to the HU that the vehicle is in reverse? If I can figure that out I am going to add a backup camera as well
Overall a great HU and the navigation voice speaks clearly and is easy to understand. I like it alot, other than that I paid for the bluetooth model and circuit city gave me the regular one. I need to complain to them about that, but it just includes the parrot bt adapter, so they should be able to give me that without much hassle.
