come say hi if you stop in prince rupert!
good to hear that you made it back to civilization fine! ... so had you decided to put the dirty 30's into your truck before , during or after the trip ?![]()
It was nice to meet you Karter, and the 77 is like a time capsule! Thanks for the chat in the rain!
Nice Cam. Is that 3/8" angle on the knuckle? I wish I did that before I assembled my axles... Not it looks like alot of work!
Great reading and watching this build move along. Truck looks great and you have done a lot of cool work to it.
What are the plans for the rear axle after the Whipsaw trip? 80 series FF or 60? My brother has about the same built truck as yours and I'm worried about his rear axles.
Dunno yet. Im leaning to "Poly Performance" chromo rear axle shafts. The problem is that the seal races are known to wear quickly as the soft material has poor wear characteristics. Im thinking a "speedi sleave" on the seal race might be the answer.
FF is another option but one can purchase many chromo axle shafts for the cost of one FF. Also Im not sure the FF axle shafts are any stronger.
What I like about a FF is if the shaft breaks it does not disable a locked truck. Pull the broken shaft and it still drives and moves. With the SF as you have found out if its breaks you are done.
A disc converserion on a sf rear can allow for "limp" mode. Stops the axle from walking out and you can go quite a ways at low speed to find a good spot to fix things.
reduces the potential of flopping when a wheel falls off, as the rotor/caliper holds it in.
not as good as a ff but better (safer) than stock with drums.
I've heard the theory that the ff axles are marginally stronger because they're the same diameter the whole way, and so don't have that hard spot where they neck down in size ( where the sf's always break) so they can twist more without popping.
but, then they have those gay little stud flanges which loosen and tear out a lot , which pretty much evens out axle strength advantage.
someone in the hardcore section drilled his out and went up a stud size, he has a morbidly obese wagon as well.
there's some nice convenience factors with ff's...not having to jack the truck up to get the diff out is a big one, and the old ones allowed nice disc brake swaps.
they also make good trailer axles.![]()
Ya its great when you do break and your wheel stays on to drive or winch to a nice flat spot to change it but but it still doesn't help the fact that you have a broken axle shaft and NONE were ever imported to Canada installed in a new vehicle... When your up in the Yukon you'll be hard pressed to find one and it won't cost $50 like a SF shaft.
Seapotatoe is bang on here, studs are a major pain. Get the Poly axles, you do have to pull them and check for twist once in a while. I've never heard of any problems with warrenty on twisted ones. I know thats a PITA but if its to much for you go Dana 60s.
The blackflag guys bust Poly shafts once in a while but they take way more abuse than the stockers. I don't think they put enough miles on them to worry about the seal surface though.
Here is the reason for the new rack. Im very impressed with the quality of this tent. I'm glad I forked out a little more cash to get the ARB over some less expensive brands.
Tent is the ARB Simpson 3 (III)
Not the ARB Pilbara.
Don't ask me about $ because a good buddy of mine got it for wholesale price. (one time deal)
Should come in handy for the Potatoe Patch event!![]()
