New Grille for the LX470
Any of yall get one from TEQ customs?
Thinking about just pulling my OEM and rhino-lining it. Seems like most of you eventually got ur orders.
The plasti-dip spray on stuff might be a good option for the oem grill, you can get it in matte black. And I think it comes off too if you don't like it, though I"m not sure whats all involved in removal. I'm happy with my grill overall. I did save my OEM one in case I want to switch back some day.
Any of you willing to let go of your 03-05 OEM LX grill, please hit me up.
What foglight housing setup is that? Any thread on those yet?
bought them from Aliexpress (again),
they are replacement of factory fog lights. you need to take care of the DRL light wires.
they are matching those headlights well.
  • Like
Reactions: ls6
Stuck my neck out and ordered through Garage Alpha Offroad for my 00 LX. Arrived unharmed 4 days after order and was decently packaged. They also responded in good time to my emails.
I tapped into the corner light, which was a pita to get off. I actually pulled the lens cover off the unit itself and had to use clear jb weld to get it back on (ugh). I pulled the light off and cut the green wire, stripped a bit back, put some heat shrink on and twisted the raptor light wires with the two green wires, soldered them together and heat shrinked them all together. The ground I just unscrewed a bolt that was holding a different ground to the body of the engine bay and wrapped the wire underneath and tightened it back up. I plan to redo that and solder an eye on the ground (actually do it the correct way). I did have to add wire to the live wire coming from the lights.
Ha!!! I had the same experience! I kept getting frustrated, going inside, then back out to try again and finally after lots of swearing the cover came off? Really??? Sorry, this just triggered me!
