New Fuel Tank Vent Hose Kits
Do you mean the vent bungs on the tank itself? I guess that they could be clogged. But, if you run a pipe cleaner through them, whatever material is blocking them will fall in to your tank. It's a lot of work to drop the tank based on a guess. I hope that you get it figured out.
Is it bad if it falls into the tank?
You don’t want anything in your tank but gas.
The strainer at the end of your pump will catch debris, but you don’t want to clog it up either.
About to be back in stock on these (been waiting on a 1000-piece order of hose clamps :eek:) and decided to do a discount for September. Use code IH8MUD to get 10% off the vent hose kits and filler neck kits :)
Bump.
Trying to get some insight on the venting system. Would anyone have any idea why I would be getting raw fuel up the vent line at the firewall? Would it be because the vent hoses have failed? Thanks!
There has always been some discrepancy about the correct sizes of some of these hoses and some are still available from Toyota, but some aren't, and since this is a common replacement item we deal with here we decided to put together a simple affordable complete kit for our shop use and for you all to purchase. The hose is made from high-quality manufactures and the clips are all correct OEM.
There is also a discount when combined with our filler neck hose kit! :)
Any luck on the new kits?
Should be back in stock on Vent hose kits Monday and filler neck kits mid-week. We sell hundreds of these a year, it’s our best selling item actually
And, it's a great product. Been running your kit on my 62 for a while now.
A related question: Does anyone know the size hoses for the fuel separator in the quarter panel?
Thanks!
