New 70 Series V8
Lets face it ,its an oversized Surf:rolleyes:
Diff doesnt look any bigger either
I suspect that tow hoop is a "get home thing" rather than a recovery point like earlier models had
I want the old model back:crybaby::crybaby::crybaby:
yep hilux has gone soft/tacoma/american(dare i say it!!) also gona come out as a 5 door too so should steal some prado sales which are just an overated hilux surf/ fj cruiser down here
Oh no you didnt;) (but yes you should!!) yes our trucks (highlux) havent been the same (IE TUFF) since the last 85 solid axle, you lucky bastards down under have it good when it comes to your choice in Toyotas. I will always own an 83 style (in my avatar)
Hmm, used to be able to put a beer on the fender - will have to work around that I guess, maybe weld a bracket on the fender.
I like the pick up!
arent you aussies ever happy? sheesh;)
send it my way (USA) I will throw a tundra 10.5 diff under it then will you be happy?! (I am not sending it back after the mods though!!)
all in all nice rig, I am guessing it will grow on you like most of Toyotas new designs (when they start "americanizing" - no diesels or solid axles then you should bitch!!!)
Those numbers are very very impresive .. not HP are only 205 HP .. but 582 lb/p of torque make me smile !!!!! :D
317 ft lbs isn't bad... be a nice swap into the older, better looking models :D
I thought 430 NM are 582 lb/f I'm fine . ?
Agree with older better loking models .. ! :grinpimp:
Im about out of allowable size to upload photos (can I change this)
Anyways here it is. Im a Toyota salesmanager, got all the info today...
4.5L v8 Turbo (1VD-FTV)
DOHC 32 Valve
150kw @3600rpm
400nm @ 2000rpm
11.9L / 100km
bore x stroke 86.0 x 96.0mm
compression ratio 16.8:1
common rail type fuel injection
turbo charger with std intercooler
Uses old H150F 5 speed - modded to suit 1VD engine
I have plenty of other specs if needed.
Dave
ill let you know next week how they drive....
Latest news is that aussie dealers will begin getting deliveries on the 23rd of March
I also heard the V8 petrol willbe available in the 79 and 76 series.
On a sad note ,the 105 series is reportedly no longer part of the landcruiser line up.:doh:
I think it would have been the ultimate cruiser,big V8 diesel wagon with solid front axle.RIP
I'm little disapointed with those performace numbers .. I'm still awaiting the real numbers for V8 Toyota Twin turbo diesel intercooler !
Something like 300 HP and 600 lb/p ..
All cool pics and all, but show us some engine pics.
Just pop the hood and show that V8!!
