Never seen this before!
Maine
Driving home the other night, and all of a sudden I hear a loud pop, and the rig starts pulling to the left, steering wheel shaking violently... I was only half a mile from home, so I slowed down, and proceeded carefully...
This morning, it finally stopped raining, so I started tearing into it... Could not believe my eyes..
Guess I'm quite lucky the wheel didnt just fall off! I've had bearings go bad before, but theres usually some warning to them, this was driving along normal, and just happened.
I'm fairly certain the bearings ran dry, I had been meaning to get in there and service them, just havent had the time...
More pix of more carnage coming soon! :D
Bet you have time now ;)
1st I have ever seen that....Impressive! Aftermarket or OEM Disc?
Last week was a pad sheared from back plate, this week a sheared rotor. Who can rip a caliper off?
I would order new Timkin Bearings (Inner & Outter), Timkin Grease and obviously a new Rotor.
That's a first, never saw that before, and like you said, you usually have some advanced warning. Glad you didn't have an accident.
LOL... No, I really dont have time... I supposed to be on the highway for a week long biz trip right now, but the rig will be the wifes only transportation while I'm gone, so gotta get it done first.
No idea if the disc is oem or am, was on there when I bought the truck.
I got timkin bearings... oddly, 1 of the 2 s***ty parts stores in town here had them in stock, Gotta wait 3 hours for the rotor tho.
Now is a good time to get the Harbor Freight Seal and Race Kit if you don't already have.
Once you use it you will appreciate how well it works. Or you can bang away on it with brass drift and hammer.
Too bad your about 1000 miles away or I would let you use mine.
Getting the bearings and races in is the least of my concerns at this point... That nut is pretty well fused to the spindle, and it looks like the axle wore its way well into the top of the spindle. At this point... I'm not really sure how I'm gonna get the nuts off, and highly doubt I will be able to use the spindle, or nuts after I do.
Ah, 2 piece rotor. Nice.
Sent from my SCH-I545
Aftermarket Spindles
Do you know when Knuckles were last serviced?
You check the grease lately by removing plug on top and putting a zip tie in there?
Now is not the season to do this work, but your in to the elbow might as well go whole arm.
Anyone know a good place to get a spindle, and nuts/washers etc? My google-fu didnt turn up a whole lot.
The Nuts are $6 each at your local Dealership.
You should be able to get a 54mm socket local as well, I'd call around before I drove around.
If not CruiserOutfitters.com sells them, I'd even bet they can tell you where to get the spindle as well.
http://www.cruiseroutfitters.com/lockers.html
Scroll down page you will see.
They have any other items you might need as well.
Amazon carries them as well for $23 with Free Shipping, just do a search.
I'm not sure when/if the knuckles where serviced... I've only owned the rig for a few months, and have been away most of the past 4 months on biz. Judging by how much work is involved in replacing the spindle... Theres no reason not to go full on with a knuckle rebuild.
@eterosoff
If I could figure out how do pm... I would lol. I am interested tho!
ETA: I do have a 2-1/8" socket, which is just about 54mm exactly, but its not getting any bite on that outta nut... it just keeps slipping.
$6 for new nuts, dont tell my wife :D
You should be able to pull the entire knuckle assembly out, axle and all by doing the "camo" method. It might be tight back there but may be easier to get it out and then you can work on the knuckle in a vise.
is it a sure thing that that method works as well on the 80?
I have read threads on here where others have done it for a trail fix. Our knuckles are just beefier.
Im gonna take a close look at everything, and replace what needs replaced... Guess its time to clean out my garage (another project I havent had time to do), and hope I can fit this rig in there. The 4runner only just barely fits, so Im not sure she'll go. Haveing a heated area and concrete floor would make life easier tho...
ETA: Id like to avoid doing the birfs till summer if possible...
I saw the same thing happened on a Cruiser I bought. Lady drove it till the bearings froze rotor sheared around the entire circumference and I believe the third blew. Not sure about the third because it was not in the axle cause the guy who tried to fix it lost the parts.
I would recommend having someone with good knowledge of these rigs take a look at your front end..! I have seen this before, you Could have a mess In there. It at least needs some serrious attention, the other side as well. Also check your diff gear lube. If your going to drive this rig go through all of It, you dodged a bullet here. Get the front end In spec. Good Luck..! :)
Pull the axles out, replace the bearings and hub/rotor/caliper, pull the front driveshaft, lock the center diff and 2 wheel that mess until you have time to do it right. It's no a fun job under good conditions, time pressure just makes it worse. This way nothing will get worse and you get on the road quicker.
