Aftermarket Spindles
Golden, CO
My spindles didn't pass the "catch a fingernail" test and my new bearings had a bit of play when slipped on so I decided to get new ones. I decided to try the aftermarket spindles that Cruiserparts.net carries. They are about half the price of OEM, manufactured in Japan, and have the new style needle bearing instead of the brass bushing. According to the label they are made by Joint Fuji or Fuji Kyogo Ltd. The model number is FTL-313A (43401-60080). They have an interesting site with catalogs. Looks like they make alot of Toyota parts : http://www.jointfuji.com/jointfuji_firm.htm
I took a few comparison pics before I installed them. For what it's worth I could find absolutely no difference between my old OEM spindles and these spindles (other than the needle bearing). I have no way to know if the metallurgy is up to par with OEM.
Not sure if I like the idea if the needle bearings. IIRC, that area of the birfield housing is sealed with just the felt gasket, right? If you go through water/mud and the housing is not full of grease (it works it way out over time), cant water/mud work its way into the housing and get lodged into the needle bearings?
That said, I am sure I need new spindles as I have have always had a problem with the wheel bearing loosen up over time and spin on the spindle. 392,000 mi shouldn't help either.
The new OEM spindles all have needle bearings as well, so I think you're stuck with that design unless you find good condition used ones. You could probably also have yours reconditioned. I'm concerned that my rear spindles are worn, and unfortunately they are not replaceable. Depending on their condition I'm going to try loctite 609 sleeve retainer. You could give that a shot depending on how badly they are worn. They have a bunch of other different sleeve retainer options depending on gap, temp, etc...
http://www.useloctite.com/filephotos/documents/Retaining_Solutions_Guide.pdf
Supposedly loctite 609 is meant to be disassembled later. Probably will have to use a torch, but from searching around it doesn't sound like it should be too bad.
That's alot of miles, I think you got your life out of them.
Are they like liquid Speedy sleeves? Does it work with where a seal has worn a mark in the steel? I should have two groves by now as I didn't seat the seal all the way just for that reason.
... According to the label they are made by Joint Fuji or Fuji Kyogo Ltd. The model number is FTL-313A (43401-60080). They have an interesting site with catalogs. Looks like they make alot of Toyota parts : ...
They are a big Toyota supplier, likely the manufacturer of the OEM spindles.
Interesting, did not realize they changed out the brass bushing for the needle bearings.
Going to change out the brass bushings out on my dads truck as they are so worn you can't see the hash marks now :0
Just out of curiosity why did I order through them as the "OEM" ones are 235 each IIRC
Loctite 609 is for bonding press fit metal parts together. In this case, you'd bond the bearing races to the spindle. For grooves from a seal, I think you'd need to use an actual sleeve.
Aichi Steel makes the spindles for Toyota...
They will have a small TEQ stamped at the 12pm position on the outside facing surface.
Thanks for the info! None the less, Joint Fuji is a quality manufacturer, they make good stuff.
