Need to borrow a Code Reader for 22RE
wngrog
Supporting Vendor
Moderator
Canton, Mississippi
Other than Chris...anyone have a portable code reader? My F Toy is throwing a check engine light and I need to know what it is seeing it is for sale...want it to be 100%
Help? I can get it back ASAP.....
N
N
pick mine up tonight have back first thing in the morning.
That is why I said other than Chris...you have to make money with yours. Thank for the offer, it would be just as easy to load my pile up and bring it.
If I can't find one I will let you know.
If its obd2 I have one you can borrow. If obd1 I have a genisis. If it has the factory connector you should be able to jump the terminals and count the flashes of the engine light. If you let me know what year the engine is ill be able to tell you which terminals to jump. Oh by the way, I have the mud flaps you were looking for I left you a voicemail but I never heard anything back.
I have a GM reader...? will it work?
It is an early OBD1...
What Terminals would I jump? Do I need the Genesis or would I just count the flashes and have you look it up?
Just count the flashes. I'll post the wires when I get to the house.
Turn ignition to on jump terminals TE1 and E1 on diagnostic plug. Count the flashes.
Thats the ones. It is the same for everything Toyota OBD1 ~85 - 94
Did you ever get the codes out of the buggy?
ok I have searched this harness and I cant find the DLC dont know if it was cut ouit or what but that plastic box with a cover of it is no showing up. If yall have any ideas on the pin outs of the computer so that I can jump the wires at the ecm that would be great. Or I can get this to you to look at ar you could come over here to look at it. Found some issues that I thought would make a difference but didnt. It will start and run fine until it gets warn, only problem after it getting to operating temp is that it will not start untill it cools down. then it will start and run fine again. Any Ideas Thannks for the input.
