Need more power!!
Friday Harbor WA
Website
www.whatzit-inc.com
Did a 750 mile trip after replacing EFI relay. All was good BUT!. :)
I had 4 kids, full sized teenagers, myself and wife with all the camping goods. Just put on my OME 2.5" lift and the ride was very nice. BUT!:doh:
I had now power up hills and mountains of northern Oregon / southern Washington around east side of saint Helens and south side of Rainer. Spent a lot of time manually putting it into 2nd and held a fast and furious 30MPH at 3K RPM up the hills. If I left it in third or drive it would just lug out or continually jump form 3rd to 2nd and back with throttle held to floor. It only has 190K :D
Compression is well with in specs but no leak down test yet. I think it is in good tune?
What all can be done for the 3FE so it can at least climb a hill in 3rd? If I could get 50MPH up a descent mountain hill I would be very happy.
Any links to sites with simple but useful 3FE mods?
P.S. it has problems with power on I5. I usually have to shift to 3rd to go up the long so so steep humps. If I leave in drive it lugs down to far, like 1500RPM. As soon as it goes to 4th the TC immediately locks up and drops around 300RPM. I sure wish I could control the TC lockup:mad:.
Some pointers for a proper running emissions system?
Valves were adjusted about 20K ago. New plugs and timing checked just before last trip. Also cleand out valve cover, air breather, throttle body ETC.
Not much else to do on these?
The transmission should hold a lower gear if you have it floored. Most vehicles will hold a gear to 4-5,000 RPM or higher with the throttle wide open in 'D'. I don't have a 3fe, but it sounds odd to me that your truck would shift between 2nd and 3rd at 3K RPM with it floored. Or is that an fj80 thing?
Power is another issue altogether. I've heard the 3fe is underpowered for the 80, and you had yours pretty well loaded. If you have oversized tires on stock gears, that won't help either. Many cars 'dog' up hills, I guess yours is one of them. There is always a way to get more power from an engine, or another engine altogether, but you will pay for it one way or another, either with cash or lost reliability- or both.
-Spike
When I drove from Norcal to Socal on I5, I hauled ass the entire way, even up past the Grapevine. I even got her up to 100 in some parts.
Get a new engine? Hahaha.
Please only post if you have real experience with these beasts.:)
"Get a new engine? Hahaha." ?? Good grief. Always has to be one.:confused:
It sounds like you need to check your cable that controls the transmission relative to throttle position. Your tranny should hold a gear and shift down sooner. Also, under full throttle, it should not lock up in 4th gear.
As far as making the truck faster with the 3fe, there are two ways, more power or less weight. Unfortunately, neither is a great solution. You might try shorter gears, but that will also compromise the situation. As others suggested, an engine swap is your best alternative.
Sounds like you were loaded down pretty good with people and gear and is similar to my power woes when loaded down. Just relax and enjoy the drive! I recently went to 33's and had some power loss there. Some guys here have gone to 4.88's and are very happy with the improvement. That is my next major mod.
uh, sorry to say it, but more power = new engine. i don't think that it is worth trying to put a turbo on a 3fe. (after the cost, you could almost do a 350 swap, and with the 350 swap you get more power, and better MPG's iirc)
it sounds like you have a good running 3fe, and as far as i know there is not anything really worth while to gain any hp for that moter
ThankS guys
That is kind of what I am after. A "bench mark" to work from.
It seams kind of strange to have to hold in 2nd and 30MPH to get up a moderate hill. Kept watching for incline or grade signs but saw none so it is real hard to know if it is doing its best or struggling. The speed thing is not really my goal. I am really after knowing if I am getting all the torque it has to give.
Is really hard to watch a year newer pass you on a hill going down I5 from Mt Vernon Washington to Seattle. I am struggling to hold 60 and they blow by me.:mad:
ThakS Cary I have read that a few times now and sounds like I have my weekend lined out for me.:bounce:
Uh, hate to say it but.... you need to change the gears.
I'm running 4:88's with a tune-up, advanced timing, and super unleaded with great results. I have stock suspension, 32" BFG AT KO's that measure about 31"es on a 10" wide rim. Tightened the throttle cable, and tranny kick down cable. The thing is night and day diff from the way it drove when I bought it. I've towed about 6500lbs up a very steep incline, run the interstate with hills, bike on roof rack, A/C running, and no kick-down out of OD. At 70 MPH with the stockish sized wheels I'm running under 3000 RPMs. The 3FE puts it's power out between 2600 RPM's and about 3500. The gears keep you right in that range, and IMOP will be perfect with 33" tires that measure up to a 33 max. I'll be running 33 BFG AT's eventually and that's it (I can say that B/C I have an off-road rig on 38's, so no reason for inchitus here).
The gears will change the beast entirely. I can merge onto the interstate without having to manually shift. Passing power is there at speeds up to about 100MPH, and the Cruiser really doesn't need to be driven that fast. I can drive mine all day at 75mph in cruise with out any downshifting. I may loose a few MPH but no down shift. By the way, it is a cruiser 3FE thing not to down-shift. The gears help keep the second to third shifting a little longer, but mine stil likes to go into 4 and OD right away.
My fuel milleage went from 9 MPG to 15 MPG by the way.
P.S. From what I've gleaned about the 3FE and it's tranny,. The Japanese model came with smaller tires than the U.S. spec ones that had 31's. They are geared from the factory with 4:10's. Bigger tires for the U.S. cruisers, should have 4:56's. I think that 4:56 is a waste of money. Improved performance comes from the 4:88's. Really matches the tranny shift points, which the 4:10's never seemed to mate.
Cheapest performance upgrade by far in the power department is a gear swap. If your keeping the Cruiser with the 3FE, change the gears. I'm almost to the point that swapping in a V-8 from another make would be sac-religious, and a mistake. The 'ol 3FE will never be a power house, but the thing is down-right bullet-proof. I really have grown to like mine. The gears are the trick.
I keep reading on this site, that the 3FE was a "mistake", or "too underpowered to run the 80 series". That's just wrong. I think that the Japanese build vehicles to last, to stand up to the riggors of Saffari's and extremes. I believe that they were pushed to change that building block behind the 80's, for the American consumer that wanted more power. Are the newer 4.5L better?, well they are more powerfull, they do offer SC's for them (still aren't satisfied are we), and they do hold up well compared to the American built SUV's. But, the 4.5L IMOP, doesn't have the reliability that the 3FE 4.0L has.
A 3FE with 4:88's compared to a similar stock 4.5L is pretty close in the power dept IMOP.
MJaddiction,
I got a 92 also looking to do the gear swap also. How much and where if you don't mind me asking? And did you do it yourself?
ThankS MJADDICTION
I am a long long time YOTA believer. Still driving my 82 SR5 extra short 4X4 pickup. 21 years now and going strong at about $50 a year in up keep, IE I think the 3FE is probably a long laster as well and have no desire to change it. :cheers::bounce:
Wife drives a 91 corolla wagon.:D
SO! How about them gears? what is the procedure and where to get? Oh and $$:idea:
I was on a Soap Box up there, wasn't I?
I got the gears from Randy's Ring and Pinion. I paid about $800 for the full install kit, and the gears. I had them put in for about $150 per axle. I spent more than that because I also bought the front axle rebuild kit from CDan, and had both front and rear axles completely rebuilt.
Expect to pay anywhere from 100 to 200 for labor per axle for gear change.. $1200 bucks really is worth it for the early 80's. If your thinking about adding a locker, do it during the gear install.
I also had to replace the front BIRFS, and at the time all the "Cheaper" suppliers were BO. I ended up buying Toyota 95 style BIRFS, from CDan... needless to say that spent the budget for the OME heavy lift... and then some... But those Toyota BIRFS sure are pretty.... :D
I see, just gearing down the differentials. Good idea. Like I say, if I am doing 60 to 70 on the interstate with out gearing down I am a happy camper.
Any idea what the stock ratio was?
100MPH in a LC. You guys are nuts!!! It is a tank not a race car.:banana::eek:
I have owned a 91 with the 3FE. Everyone here has seen me exclaim "3FE Powa" on more than one occasion.
I speak from experience.
Cool DanKunz
Have a point? Tips? suggestions to bring mine back up to par?
The stock ratio is 4:10
Cool DanKunz
Re-read my post earlier :)
You have one of the weakest engines for high speed travel for the size of truck you have. Sorry, it is what it is.
Now, offroad, and low speed, it is a happy and VERY durable camper.
So, if you want to pass on the highway with a 3FE...
You can do a complete tune-up, eliminate all the vacuum leaks that develop over the years, open up the exhaust and intake to let the engine breath a bit more, etc.
These will get you noticable improvements, but you will still get passed. I think the investigation in shift points, etc is valid as well. Regearing will help a bit too. All of the above plus the reference to the 3FE power build (Robbie at Slee has done this for others, it is not cheap....$8kish) will get you to a somewhat more powerful truck.
If you want more than moderate improvement from your experience you need to spend major money on a tuned 3FE rebuild to get better numbers or swap in a different power plant.
It is what it is. You just have to grow to accept and appreciate it for all that it is...a modified and suped up tractor motor.
Sorry, that is the end game for the 3FE that isn't a lower speed/city/trail truck.
