Need more power!!
Sorry i thought most people on this forum knew about Rodney from Wholesale Automatics here is his web address( www.automatictransmission.com.au) as he has the most experience in toyota auto's i have come across , he is the only one with modified valve bodies etc etc .....:cheers:
When I disconnected the EGR on mine, I was able to hold overdrive with stock gears and 35" tires. Then I buned up the transmission from previously shifting gears and downshifting. But it was like night and day when I disconnected the EGR. This of course was just seat of the pants testing...; )
I find that I do fine when climbing hills fully loaded (ie; eastbound I-90 over Snoqualmie Pass) when I maintain my rpms between 2600 and 3200.
Most of the time I have to manually shift it down to 3rd to make it happen because 4th gear lockup occurs at 47 mph and doesn't help when climbing hills. Unlike some thoughts, I have no problem manually up-shifting my FJ80 to get up to highway speed, especially on hills.
4:88 gears are next on my list of things to do, however I'm waiting and installing lockers at the same time.
Steve
When I drove from Norcal to Socal on I5, I hauled ass the entire way, even up past the Grapevine. I even got her up to 100 in some parts.
Get a new engine? Hahaha.
With 38s and 4:88s I can only do 94 mph!:cool:
Can't you just replace the 3fe with a motor from a 93+? or is that a ton of work?
At a minimum, I think you would also need to replace the ECM, wiring harness, and then deal with compatibility of the transmission/Trans ECU.
