Need help with the front suspension
I have a 72 landcruiser and it was hit on the street the other day by a lose trailer, well the trailer popped the front tire and knocked the cruiser up onto the sidewalk, it didn't look like much damage some paint scrapes and a flat, but i looked at the suspension bar on the front driver side and it had come unattached from the frame. I see it was connected to the frame in a horizontal fashion as well as a vertical fashion. The way that it was connected horizontal was by some sort of bolt which i can no longer find, and the way bolt that was connecting it vertically was busted off with some of the bolt still showing, how would i replace these bolts and what kind of job would it be? Thanks for your help and can't wait to hear from any of you.
Suspension bar?
Do you mean part of your steering? Center arm pivot?
Mark...
Here are some pictures of what it looks like, the first 2 pictures are from the side and the last one is from the bottom, thanks for all your help, the last picture shows the bolt and the hole
thanks again
suspension 3rd picture
the last picture didn't show up, but here it is
thanks
front suspension broken bolts
Here is the 3rd picture of the broken suspension, you can see the broken bolt and the hole where it should go
Okay. That's not a bar. It's a spring. Leaf spring. The part that has torn loose is the spring hanger. It is not bolted on, it is riveted. There is a good chance that there is more damage if the hit imparted enough force to tear this loose. Check the shackles and shackle hanger at the other end of the spring. Check the spring. Check the frame. Check the ubolts securing the axle to the spring. Check the steering linkages.
IF this is the only damage, the spring hanger can be bolted back in place (but it is tough to reach the inside to install the nuts on the bolts. The simplest and easiest way would be to weld the hanger back in place.
Mark...
i am having a heck of time posting pictures, here are the 2 side pictures with the bolt missing, what would the bolt be called so i could get one, how would i line the the holes up without damaging the spring
Again, they aren't bolts. They're rivets. You can't easily get them or install them without tools that are not commonly in a home garage, enthusiest's toolbox or a small shop. That's why I say that the simplest and easiest way to fix this is to weld the hanger on. If the spring and hanger will not easily shift back to position, then something else is bent. Check the other items I mentioned.
It sounds like you might want to farm this job out to someone who is more familiar with this sort of repair work.
Mark...
s*** if i knew it only took a trailor to knock those things off i would have gotten a trailor insteed of hours with a grinder
bwwaaaaaaaaaa haaaaaaaaa, thats funny
thise rivets are little bastards to get rid of, i feel your pain coolcruiser
