I need help with a wiring issue and hope that someone smarter than me can help me.
I’m trying to install a device in my 79 FJ40 that will have power only when the ignition switch is in the ACCESSORY POSITION AND a MOMENTARY SWITCH is being PUSHED.
I know the device works because I’ve confirmed it by running 12 volts directly to it.
I have also confirmed the device has a good ground.
I have included a wiring diagram below to show how the device is wired.
To power the device, I tapped into the power lead from the fuse box to the radio.
When I turn the ignition switch to the ACCESSORY position the radio works and the device remains off, as it should. So far so good.
Here is the problem:
When I push the MOMENTARY switch with the ignition in the Accessory position the RADIO GOES OFF and the devise does NOT work.
I hope someone can tell me what I did wrong.
Thanks
Thanks
