Are you wiring this according to the
Holley instructions?
This instruction specifically says to use a relay, if you aren’t using an OPSS... I don’t see an OPSS in your diagram.
The fact that they specifically say to use a relay suggests the same concern
@Living in the Past expressed... the chance of overloading an OLD ignition and OLD wiring... be warned.
“7. Connect the RED (positive) power lead to the OPTIONAL OIL PRESSURE SAFETY SWITCH
or
TO A RELAY CONTROLLED
BY IGNITION. If this pressure switch is not available, connect to the ignition switch voltage supply terminal.”
You said, you’ve fused the momentary switch circuit fragment in accordance with the Holley “3-5 amp” directive, on a 5 amp radio circuit.
IIRC you are fusing your device at 5 amps.
Is the radio circuit still fused at 5 amps?
Holley’s 3-5 amp requirement suggests the pump could draw the full 5 amps at times.
How much does the ignition-side of the radio draw?
I’m a twice retired software developer... not an electrical expert. I don’t recall all of my high school electronics... yes, we had electricity in the mid 60s
But, resistance is a major player... since you split your (diagramed) circuit into two circuit branches, which branch is physically shorter?
Since the radio circuit is 5 amps and the pump
can draw 5 amps, it
seems possible that the pump is the physically shorter fragment, drawing too much to allow the radio to remain powered on. This would explain why the radio shuts off.
This test appears to confirm that the above is your radio shutoff problem.
“With the ground wire removed from the device:
One lead of the mulitmeter connected to a good ground on the body
The other lead connected to the input of the device
12V at the device
The radio DOES NOT cut off
The device will not work because it is ungrounded”
Regarding the switch and pump, you also said “
The device shuts off when the button is released. The device will NOT be used when the engine is running.”.
If your device is a fuel pump, I don’t understand how the fuel pump will not be used with the engine running.
Regardless, I suspect the switch switch/device issue is also a result of splitting this 5 amp radio circuit.
You (Edit: still using the radio circuit) could fairly quickly eliminate potential wiring/ignition overload and provide a dedicated battery+ power circuit, to the switch/pump by simply wiring a relay into your RB fragment, between the switch and the device.
I’m sure that would solve your radio issue and am relatively sure the relay would also solve your device issue.
Good luck
BTW
You should SERIOUSLY consider adding an OPSS, if the pump is used to pump fuel, while driving.
The OPSS will shut the pump down anytime the oil pressure drops below 2psi... but, will allow you to start the engine, with oil pressure below 2psi.
It could prevent burning down you and your 40, in the event of an accident.
