Need Help. What is the Factory Dimensions for Location of the Vader Light & Switch to the right of the Pocket (Glove Compartment)?
Green Bean
Texas Coast
I sure would appreciate it if someone with a factory original Vader light could tell me the dimensions for locating correctly locating the holes. Thank you.
Nicely played….🍺
Good thread Bean :cheers:. With the Racer Repo light, and the availability of a “correct switch”, might see a few additions to other projects/retro fit(s). I’ll most likely switch out the bulb to LED IOT shed some light on that side of the cab. I even kicked around the idea of adding two Vaders with LED’s. One right of the glove box and one left of the gauge cluster. I figured that would arouse the ire of the “Vader cult” so I nixed it…😁
Good thread Bean :cheers:. With the Racer Repo light, and the availability of a “correct switch”, might see a few additions to other projects/retro fit(s). I’ll most likely switch out the bulb to LED IOT shed some light on that side of the cab. I even kicked around the idea of adding two Vaders with LED’s One right of the glove box and one left of the gauge cluster. I figured that would arouse the ire of the “Vader cult” so I nixed it…😁
@Chungas Revenge please let me know when you find a LED bulb part number/vendor etc. I like the idea of an LED but also think that the little incandescent put out the correct hue. Thanks.
@ToyotaMatt i need that switch is it on your website? I just need the regular kind, not the #snowVersion !!
here is the link below ,
so if i may ask ?
how do you plan to insulate the 2 rear wire lugs on the back side , and prevent them from arcing , and turning your cowl harness into ashes in only single digit metric seconds ?
that grey rubber tail-boot is OEM genuine
SUMITOMO japan spec. part , this ain't a lets wait and see topic here , if you follow me here .....💥
thanks
For anyone who cares to go with a LED Light bulb in the Vader, here are a few options that I found:
SuperBrightLed's.com:
Amazon:
Amazon product ASIN B09QY9MBPS
Amazon product ASIN B07VWXNJBQ
https://www.amazon.com/dp/B097MMQ2WB?tag=ihco-20
Amazon:
Those look like good options. All my interior lights (🤣) are LED. Gauges, dash etc.
Haven’t made the leap outside of the cab yet.
