Pfft, Aisin Seiki!You have the wrong transmission, you 4L80 is not geared for your set up, you can get some 3.54 gears from Australia or the Sumo with the over drive gears, you really should have used the Allison![]()
Should have used the Allison? Don’t want to sound rude but have you put a duramax into a 80 series before?You have the wrong transmission, you 4L80 is not geared for your set up, you can get some 3.54 gears from Australia or the Sumo with the over drive gears, you really should have used the Allison![]()
You still running the factory t-case in your build?lol why
pics and info of duramax swap lol
forum.ih8mud.com
Ignore him. He’s a troll 99% of the time. His way or the highway. I for one like seeing your build progress. Tue last giy I saw with the dirty max had all kinds of issues with the Allison fitment.Should have used the Allison? Don’t want to sound rude but have you put a duramax into a 80 series before?
Yes but that's downstream of my motor and upstream of my axlesYou still running the factory t-case in your build?
I guess I don’t understand what your saying? Have you put a duramax in a land cruiser? What do you mean by “messy”?Is the Duramax running stock programming? If so, it will feel terrible with 4.10's/33's.
Get some EFIlive action going on or atleast one of those TPS amplifier devices so you don't have to mat the pedal to get 2500 RPM and it will be fine.
Or go to 35's. That would put you same gearing as a stock GM pickup with the duramax.
Duramax swap is way too messy to ever appeal to me, but I am carefully planning a healthy and clean 12 valve and 6 speed Allison swap into an 80. My tape measure says it will fit fine with the right combination of p
If you used an Allison 6 speed your RPM's would be fine.
I’ve been driving my cruiser with the duramax for a couple weeks now and im not sure what you mean by “it will feel terrible”, lol like I’m seriously driving it daily and your telling me it’s going to feel terrible lol, come on now
I do agree after some efi live it’s going to have more power, but as it is now it’s a night and day difference then stock engine
Can you post up a link for a Allison to toyota transfer case adapter? I didn't know there was one. Do you have a Allison in your land cruiser?You have the wrong transmission, you 4L80 is not geared for your set up, you can get some 3.54 gears from Australia or the Sumo with the over drive gears, you really should have used the Allison
Stock axles should hold up fine unless it's a rock crawler.Duramax and stock axles lol why
I think your going the right direction. I looked into going with a diesel swap and gearing was a big concern to me as well. I also don't like tall tires on a daily driver. I would look into the 3.54 gear Set. I have a feeling the tcase gears won't be enough.I’m running a Duramax and a 4l80 transmission, at 75mph I’m sitting around 2500rpm which is high for the duramax, I have the power to move the land cruiser so I don’t need the rpm
I am telling you guys, I have over 200k on a Duramax with 4:10 gears and have had 35's and now 33's on it for the last 50k. It is just fine. I normally cruise at 70 mph 2300 rpms and it is fine, 20 mpg. it will do 90 or higher no problem as well. Mine is a LB7 and 5 speed Allison. The 4L80 is a 25% overdrive. Should be fine. I really think everyone is overthinking it. I would focus on fine tuning everything and enjoy it.
Lol why
