Need FJ40 help!
Wilkes-Barre,Pennsylvania
I have owned my FJ40 now for two years and put approximately 20 miles on it since bought. I have been looking for someone that knows their s*** on these things! I am in the Wilkes-Barre/Scranton area of Pa. Two issues that are going on with it:(1) It won't stay running after I go about two blocks with it. It starts bucking then just dies out. It has a brand new Weber on it,changed the fuel filter on it a few times already and also put a brand new fuel pump on it. (2) It has a painless wiring system in it that the previous owner screwed it up royally! Any help would be appreciated! I want to make it to Rausch Park with it this year!
Look here for a club local to you: Clubhouses | IH8MUD Forum
Can't help you with the Weber. I'm not fond of them, but others here know more about them. It does sound like a fuel delivery issue to me though.
I agree the original carbs always Win out. You can’t kill a Toyota part.. also I’m working threw a similar stalling out problem.
Things to consider:
-is the carb adjusted correctly
-will it go farther with the choke pulled- if so it may be a vacuum problem.
-with the vacuum- is the line to your break booster secure, could cause extra air in and is thinning your mixture.
-is there junk in your fuel filter? Mine had constant crap, so I replaced or blew out all the lines.
-Also see if there’s crap or rust in the tank. It will choke out your lines preventing flow.
I hope this helps. I’m new myself, but have been up to my elbows since the day I brought mine home. I don’t know your year but mine is a 77, so that’s where my knowledge is from. Good luck!
First welcome, second waaaay more info needed about your cruiser, pics too. Check out the Keystone Cruisers sub forum on here. An active bunch with a lot of local knowledge.
X2: before you throw more parts at it, you need to meet others who can advise you on the best course of action
