Plan on replacing the OBDII fuel injection with a mega squirt. It will never be happy with what you are doing. EGR does not raise engine temps. It lowers them by reducing cylinder temps when it goes into lean burn. You run the risk of burning valves and pistons without it. A cat does not raise engine temp. If you get a IR thermometer you will actually see that the temp after the cat is higher then in front of it. Modern cats are very free flowing. If you are having cooling issues your problem is else were. My fully smog compliant 97 is actually concerning me that it's running too cool I'm concerned the ECM isn't happy and running rich. Modern FI needs to achieve a certain temp to operate correctly so you are not going to make it happy if you do stuff like put anything but stock spec thermostats. You want to help keep it cool put a bigger transmission cooler on it and then leave it the hell alone if it's not throwing codes. Like others keep telling you In all these related threads.....you are making more problems then you are going to solve. Fix the EGR and leave it along for then next 15 years till it breaks again.
