My 80 needs some repairs/services. I'm not sure how to prioritize some of the repairs, so I'm hoping to get some help here.
Distributor O-Ring Replacement -- mechanic says o-ring is leaking oil onto belts. Says to replace now and re-time engine. This repair is pricey at close to $300. I'm not sure I need it right away. Please advice on what happens if I ignore this repair for now.
Front Wheel Bearing Adjustment -- mechanic says there's play in one of the front wheel bearings. Wants about $100 to tighten. What happens if I don't do this service now? I had the grease changed and the wheel bearing re-packed last year.
Replace drive belt. Mechanic says the drive belt has oil from the o-ring leak and I should replace now. I replaced the drive belt about 65K miles ago with a Toyota OEM belt. Can I just use a cleaner like Simple Green to remove some of the oil from the drive belt? This repair is pricey at $370.
I'm doing other repairs already like brake fluid exchange (says brake fluid is dark brown), throttle body service, and fuel system cleanout/service. I'm also going to replace the oil/filter at this shop.
Please let me know what you think about these repairs/services. Your responses are appreaciated in advance.
