Big list of things to do this Sunday... one is the oil pump seal, and I can't seem to locate a torque wrench (for re-installing the crank pulley) that goes above 250 ft/lbs. Please correct me if I'm wrong, but I understand that its spec'd for 305 ft/lbs... ?
Other things I'll be doing:
Replace fan belts
Install new fan belt idler assembly
Replace oil pump cover screws with new ones
Replace oil pump seal (anyone recommend using rtv/silicone?)
Replace front crank seal (use 2" pvc as spacer to re-install seal?)
Replace a heater hose that looks degraded
Replace lower (2) radiator hoses
Replace aluminum coolant bypass tube (and the 3 o-rings) that goes from the head to the water pump housing (mine has a hairline crack).
If all this goes well, I might attack the PHH, but suspect that will have to be another day.
I've read through many of the threads, but I welcome any advice!
Thanks.
Replace fan belts
Thanks.
